How Would you lower the car?
Old Oct 11, 2003 | 12:35 PM
bassik277's Avatar
This might seem like a stupid question, but i must confess ignorance with regards to the topic. If you wanted to lower the car about 3/4" to about an 1" would you need new coilovers? Or new springs? Or is it possible to somehow simply use the stock suspension? And if it were possible to use the stock suspension would there be any adverse affects on handling? Or the warranty of the car? Thanks a lot guys
Old Oct 11, 2003 | 12:42 PM
goodyrx8's Avatar
You can get a shorter set of springs and keep the factory shocks or get springs and shocks as a package.
Old Oct 11, 2003 | 12:45 PM
rabinabo's Avatar
don't use the stock suspension
The only way to lower with the stock suspension would be to cut or heat the springs, but that's inadvisable. It'll make it ride like something the Clampetts would drive. You can get either springs or coilovers.
The coilovers usually allow you to adjust the height and are more performance oriented (but usually give you harsher ride) and the real ones come with a shock tuned with the springs. If you just want the drop for looks, then quality springs would be just fine, like Eibach. I don't think they make any for the 8 yet, but give it a little time and there will be plenty.
The one thing to worry about is how much it will throw off the camber (notice how some cars have the top of the wheels pointing into the car, that's camber), but the stock suspension seems to allow a lot of adjustment so you should have a problem getting it balanced. After the switch you should always get an alignment.
Old Oct 11, 2003 | 05:44 PM
mikeb's Avatar
100% Italian
I want springs to lower mine about 1 and half inch
Old Oct 12, 2003 | 05:14 AM
m0j0's Avatar
you got m0j0?
go buy your self some coilovers It's worth the money
Old Oct 12, 2003 | 07:33 AM
goodyrx8's Avatar
Check out japanparts.com and some of the other aftermarket vendors for ideas. There are a few different companies, including Mazda Speed, that make shorter springs and coilovers.
Old Oct 12, 2003 | 01:36 PM
energie's Avatar
autoexe makes springs for the 8 too
Old Oct 13, 2003 | 02:21 PM
mikeb's Avatar
100% Italian
I cant wait til I can get these parts at a car shop locally instead of ordering from the internet and paying shipping from japan and what not
Skyl3r
Dec 2, 2019 04:51 PM
akagc
Aug 11, 2015 07:07 PM
Jazzmeson
Jul 31, 2015 01:47 AM
dbarber
Jul 25, 2015 01:34 PM
