What are some symptoms that mean its time change my transmission fluid?
Old Sep 4, 2007 | 03:32 PM
TeeFar's Avatar
6 speed manual
What symptoms should I look for? I was planning to have it done this week mainly because I bought my car used in July and I don't know its been changed yet.
Just curious yall
Old Sep 4, 2007 | 04:02 PM
½mv²'s Avatar
printf("</%i pistons",3);
Good question - I'm actually kind of currious about this myself. I didn't get my tranny fluid changed until I had 60,000 miles on her, and I didn't notice any difference between the old stock gunk and the brand new synethic top-notch stuff...
My advice would be this regardless - if you're unsure, change it. It doesn't cost much to do, and once you do it you're set for a very long time, and you don't need to stress over if you should or shouldn't get it done anymore.
Actually, now that I think about it, how many miles did she have when you bought her? Unless you got her with real high mileage, you might be worrying over nothing.
Old Sep 5, 2007 | 01:19 AM
corners's Avatar
An RX ate my baby
If you have symptoms, you waited too long. You don't wait for your engine to make funny noise to change the crankcase oil, do you?
Old Sep 5, 2007 | 01:40 AM
i would start with the owners manual..
go from there..
Old Sep 5, 2007 | 07:16 AM
savedsol's Avatar
Carbonormous
go from there.
How could you ask someone to do such a thing!?
Old Sep 5, 2007 | 09:06 AM
Haze's Avatar
The dealership forgot to do it on my car so it didn't get done until 50K miles. The symptoms that I had were the gears being very hard to shift in very cold weather and the trans sticking in first and needing to be pulled out when the weather was very cold. In warm weather there were no symptoms.
The oil should be changed reliably every 30K miles in both the transmission and the differential. I'd just do it if I were you. The ultimate siign that it needed to be changed is if the drained fluid is shiny, which means that it has trapped metal particles in it.
Old Sep 5, 2007 | 10:33 AM
mac11's Avatar
Rotary , eh?
That probably won't happen since the drain plugs are magnetic.
Old Sep 5, 2007 | 10:40 AM
Haze's Avatar
Magnetic drain plugs pick up chips, but not small particles that never come out of suspenison that lead to the shiny look. Probably won't happen? That's how my oil looked when it was drained so I think that it is possible if perhaps not probable.
Old Sep 5, 2007 | 01:26 PM
just change it once a year and your car will love you.
Dokuji
Nov 1, 2016 02:51 PM
DJclever
Sep 6, 2015 10:51 PM
akagc
Aug 11, 2015 07:07 PM
CRAZ8
Jul 22, 2015 10:02 AM
