rx8 2 rotor
Old Nov 13, 2002 | 06:53 PM
unemployedpimp's Avatar
Pimpdaddy
Question rx8 2 rotor
some of you guys are a little disapointed about the rx8 which only has 2 rotors, maybe the mazdaspeed will come with 3 or 4 rotors , a TURBO for sure , the turbo better have more pounds of boost , like 24 or higher.
Old Nov 13, 2002 | 06:59 PM
wakeech's Avatar
mostly harmless
uhhhh... guys???
repeat after me: "If you can't say anything nice..."
actually Unempimp, this's being discussed in another thread...
btw, do you have any notion at all of what 24psi of boost DOES to an engine?? didn't think so...
Old Nov 13, 2002 | 07:12 PM
Grimace's Avatar
Certifiable car nut
24 psi?!?!?
Maybe if I want the rotor to shoot through my fender!
Old Nov 13, 2002 | 07:30 PM
that would sure suprise the annoying guy at the stoplight who was trying to race you:D
Old Nov 13, 2002 | 07:33 PM
RedRotaryRocket's Avatar
Easy there guys...maybe he meant absolute pressure
Old Nov 13, 2002 | 07:59 PM
Donny Boy's Avatar
Check out the 3 rotor post in the "requests section".
Old Nov 13, 2002 | 10:09 PM
Hercules's Avatar
Yes, I hope the MPS or Mazdaspeed RX-8 does NOT have a turbo.. there is something about the throttle response on a NA car that is just ooo.... *drool*
They can add more carbon fiber to the body/chassis and reduce weight more, and add the 3 rotor.. that will be the most effective production for the Mazdaspeed RX-8, instead of adding a turbo and stuff that adds insane weight.
The rotors weigh something like 12 lbs, and increasing the rotor housing shouldn't be that much weightier... say they add a max of 100 lbs to the car due to the engine, then reduce some more by using more carbon fiber... Yup, that would do it for me.
I hate turbo cars because in hot weather they will slow down off their specs... lag sucks, and you have have the thing idle before you turn it off... nah, give me NA any day over turbo. I hate turbos.
Old Nov 14, 2002 | 09:50 AM
Sputnik's Avatar
Originally posted by wakeech
...btw, do you have any notion at all of what 24psi of boost DOES to an engine??
If the engine is built for it, it makes for one helluva strong engine.
---jps
Old Nov 14, 2002 | 03:11 PM
Pimpdaddy
ohhh guys im sorry!!
im just 14 years old and im happy about the rx8 , i saw how the maazdaspeed protoge , its turbo only had like 5.3psi and i got frustrated and why not 24psi , i saw a IS300 with a turbo that has 24.0psi!!! i think the rx8 can handle that!
Old Nov 14, 2002 | 03:55 PM
1.3 liter's Avatar
Exclamation Hold Up!
You're just 14 and your screen name is umemployedpimp? Is pimping something you do after homework or is this a future profession?
Old Nov 14, 2002 | 04:36 PM
RX - 8's Avatar
Moderator From Hell
belongs in discussion forum. moved
Old Nov 14, 2002 | 08:57 PM
MikeW's Avatar
Quad rotor. Heck no!!!
A quad rotor is like an inline 8 cylinder engine. Fires like an inline 4. A quad rotor fires like a dual rotor.
Tri rotor
Old Nov 14, 2002 | 10:51 PM
Hercules's Avatar
Re: ohhh guys im sorry!!
Rotaries don't like excess heat... the 13B would tell ya that.
Anyway I would not buy a Mazdaspeed RX-8 with turbos.. 3 rotors and lighter weight, YES, but not with a turbo. I just don't like turbos.
Old Nov 14, 2002 | 10:57 PM
Red Devil's Avatar
Anything near 24psi seems like a tall order for a production rotary...but then again, what do I know?
As far as blowing 24psi through a Lexus IS, Toyota's cast iron blocks are tanks. They can take most anything you can throw at them. (At least I think they are still cast iron, they were in the last Supra.)
Old Nov 15, 2002 | 09:13 AM
Sputnik's Avatar
Still, the engine had to be rebuilt to handle that kind of boost for more than a couple of weeks. The block might be able to handle it, but normally things like head gaskets, pistons, con-rods, cranks, and even valve trains will need to be upgraded to put 24 psi on a production NA engine.
---jps
Panthersn
Jul 13, 2021 06:30 AM
blainezoomzoomrx8
Sep 9, 2017 08:29 PM
SupraG
Sep 21, 2015 12:09 AM
Eastcoastmod
12
Aug 27, 2015 06:29 PM
Bamaham
Jul 23, 2015 08:08 AM
