Differential Checking
Old Jul 24, 2007 | 01:39 AM
rotaryPilot's Avatar
Hi everybody,
Is there anyway to check that my differential is working properly?
The only information that I have is that if the differential is quite and does not make any strange noise everything is ok. Is this true?
How is it possible for someone to detect a problem in the RX-8 differential? What kind of checks can he make apart from changing the fluid and looking of meta shavings.
Old Jul 24, 2007 | 09:23 AM
SureShot's Avatar
The only way for it not to work is to destroy itself.
If that happens, you will hear it.
Old Jul 25, 2007 | 06:26 PM
climacus's Avatar
From a standstill, accelerate in first gear and take 90 degrees turns (like left turn at a traffic light). If you hear any noise and vibration from the diff, then the fluid is burnt and you need to change the differential oil.
Old Jul 27, 2007 | 05:08 AM
^ This is very useful information. Apart from this check that you have described I assume that if no noise can be heard from differential everything works fine. Is this correct?
LB2739
Jul 9, 2019 02:25 AM
Danield97
Oct 10, 2015 05:58 PM
Forevermore
Sep 20, 2015 01:04 PM
Irvinb16
Sep 11, 2015 10:27 PM
