Streets of Willow Springs -- 21st
Old Jul 19, 2007 | 12:25 AM
kinchu007's Avatar
Talking Streets of Willow Springs -- 21st
I'm going to Streets on Saturday.
Is anyone else going?
http://www.redlinetrackevents.com/
Old Jul 21, 2007 | 07:47 PM
kinchu007's Avatar
Wow...it was a really hot day...my radiator fluid spilled all over the K&N Intake (well, not much of it but it scared me)...the temp gauge liked to be half way between normal and red.
Are you guys running 5W-20 on the track? It seems like at such high temps it would not be an ideal choice.
Anyone have a biggest-bang-for-the-buck cooling mod? I'm planning to track it once a month, so a little worried about the coolant temp! Does Water Wetter help?
Old Jul 21, 2007 | 08:02 PM
Derex'8's Avatar
ReDuX
Ask and ye shall receive...Click Me!!!
I would use 10-40 or 5-30 at the track. Add some pre-mix.
Don't keep down shifting keep it in the higher gear and the temps will drop drasticaly.
Best thing is to get a vented hood.
Old Jul 21, 2007 | 11:01 PM
kinchu007's Avatar
Slideshow: http://www.kodakgallery.com/Slidesho...Uy=p4u1js&Ux=0
You can see the coolant leak towards the end of the slideshow.
Old Jul 24, 2007 | 11:17 AM
kinchu007's Avatar
Thanks for the link to the radiator fan mod.
Tripoint Engineering says I should run water plus Water Wetter with no coolant in my radiator. Anyone doing this? Won't the water boil and then evaporate? I guess you can just keep adding water?
Thanks in advance for any advice.
By the way it was 40 degrees Celcius on the track that day at Willow.
Old Jul 24, 2007 | 11:54 AM
ULLLOSE's Avatar
05-08 SCCA BS Natl Champ
You wont get all of the coolant out of the system with out a rebuild. I have been using WW and water in all my cars for the last ten years.
Old Jul 24, 2007 | 01:08 PM
kinchu007's Avatar
Ok, so it's safe and effective...thanks for the reply!
Anything I need to know about maintenance? I'm assuming that I just refill with water as needed? Will it ever get hot enough to actually steam / boil out? Sorry if this is a noob question...
Old Jul 24, 2007 | 01:25 PM
SouthFL's Avatar
Does anyone on this forum us a radiator shroud like this to help keep airflow concentrated on the radiator?
Old Jul 31, 2007 | 10:56 PM
SolarYellow510's Avatar
Follow the WW directions.
Basic benefit is that water has a much higher specific heat than propylene glycol or ethylene glycol, so for every degree of temperature rise, pure water takes more heat out of your engine than a water/antifreeze mixture. Water also transfers heat more effectively, so for a given temperature difference between the coolant and engine, or coolant and radiator, more heat will be exchanged. Water Wetter has corrosion preventing features (like antifreeze), as well as reducing surface tension, resisting the tendency to form bubbles and boil.
The downside of a straight WW-water mixture is it doesn't smell, so if it's leaking, you won't know as soon. A friend of mine got to rebuild an engine last summer because of that. If you run maybe 10-15 percent antifreeze, you'll know by the smell if you have a leak.
I live in SoCal, so I can't speak to the safety of WW without antifreeze being run through a real winter (freezing resistance).
Oh, yeah. It was only 99 at Streets that day. That's one degree shy of officially hot. Stop crying J/K I was there, too, but not with an 8.
Old Aug 4, 2007 | 10:22 PM
kinchu007's Avatar
Track temp fool not air temp! Seriously though, thanks for the post...I've been doing a lot of reading the past week and have a pretty good understanding of the cooling system now...good point about the coolant being "smell-able"...it still scared me how hot it ran...no wonder turboing these cars wreaks havoc...a part of me wants to think that the 8 runs hotter than the 7...oh oh, flame city!
Old Aug 7, 2007 | 11:55 PM
That's the first time my car ran hot. Damn it is hot there.
tbiggybig
35
Jul 14, 2022 06:14 PM
Hunterkelley24
Jun 14, 2022 08:32 AM
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
RX-8 Racing
20
May 14, 2016 06:25 PM
duworm
Oct 1, 2015 04:57 PM
