Diagram of o2 sensor harness? Help
Old Jul 10, 2007 | 05:46 PM
Travis Mitchell's Avatar
Question Diagram of o2 sensor harness? Help
Well I collected a roadkill a diesel shot at me under my 8. In the process it managed to pull the wires right out of the harness that connects to what I'm assumeing is the O2 sensor in the exhaust. The wires are good and they will pop right back into the harness but unfortunately the colors of the wires change there so I cant just match them up. Can anyone help me on this? I tried my local dealers but no help there.
Old Jul 10, 2007 | 06:15 PM
front O2 sensor (in the exhaust manifold) or rear O2 sensor (at the cat converter)?
Old Jul 10, 2007 | 06:24 PM
Front sensor. The wires are still intact going out the connection and into the sensor its the other side of connection that pulled out. Any help u can give would be appreciated. Thanks
Old Jul 10, 2007 | 06:45 PM
Just climbed out from under it and I was wrong it is the one that hangs down. Found the other on top where you said it would be.
Old Jul 10, 2007 | 06:48 PM
StealthTL's Avatar
Cool Sorry......
Sorry, I mis-interpreted the diagram, gave the wrong colors.
The diagram doesn't show what colors the actual sensor side of the connector is - and it's probably those that pulled out.
The wires from the ECU, as you look up into the open terminal side are -
yellow - top right
blue/red - bottom right
red - bottom left
white/red - top left
S
Old Jul 10, 2007 | 06:52 PM
The wires are still in the sensor and they are intact into the harness. The wires that pulled out are from the other side of the connector so you may have it right.
Old Jul 10, 2007 | 06:57 PM
the wires on the sensor side are different colors that the wires on the harness side
StealthTL's Avatar
Cool That's good.....
If the sensor wires are still in place, the above colors should do it. Look at the connection side, where it makes contact, and work clockwise.
S
Old Jul 10, 2007 | 07:06 PM
see attachments
Attached Thumbnails Diagram of o2 sensor harness? Help-clipboard.jpg   Diagram of o2 sensor harness? Help-clipboard1.jpg
Nisaja
Aug 6, 2015 01:27 AM
Stubbs
Jul 28, 2015 09:23 PM
KGBeat
Aug 20, 2013 10:31 AM
RotaryResurrection
Nov 28, 2008 10:26 AM
