(!) Tire Pressure Light
Old Jul 6, 2007 | 05:03 PM
OL!z RX8's Avatar
«ΩLi√∑RX8™...
I got a small problem, the light with the (!), I think its the tire pressure light, lights up most of the time I turn on my car. I checked my tires and filled them up with air already, but the light doesnt go away. Anyone experienced the same problem? Or knows what to do before I take it to the dealership?
Old Jul 6, 2007 | 05:15 PM
dillsrotary's Avatar
jersey fresh
you have to reset the light, its in the manual
Old Jul 6, 2007 | 06:05 PM
CTrx8's Avatar
space for rent
does it flash or stay on?
Old Jul 6, 2007 | 06:18 PM
OL!z RX8's Avatar
«ΩLi√∑RX8™...
it stays on and also sometimes it beeps like 3 times and stops
Old Jul 6, 2007 | 06:20 PM
OL!z RX8's Avatar
«ΩLi√∑RX8™...
reset?...ok..ill look into that...the red seat belt light its alwayz on also, and i alwayz buckleup, do i have to reset that one too?
Old Jul 6, 2007 | 06:23 PM
shaunv74's Avatar
Power!!
Do you have stock rims?
Old Jul 6, 2007 | 06:43 PM
OL!z RX8's Avatar
«ΩLi√∑RX8™...
yes, I do have stock rims...
Old Jul 6, 2007 | 07:19 PM
CTrx8's Avatar
space for rent
sounds like more of an electrical problem if you're saying it is beeping (which would tell me it's not a malfunctioning TPMS) but the pressure is fine and your seatbelt light is on but your seatbelt is buckled. this is a longshot but have you checked the fuses?
Old Jul 6, 2007 | 07:52 PM
poweredbyplaav's Avatar
i had a similar problem, but only the tire pressure light would come on. i kept checking my air and pumping it to about 32 (or what i thought was 32). well i took it to the dealer today and it turns out that the gauge in the air pump was not accurate and i had about 45 psi in the tires...which is why the light was on. so long story short, dont rely on the air pump gauge bcuz you may end up pumping in more air than you think
Old Jul 6, 2007 | 10:58 PM
OL!z RX8's Avatar
«ΩLi√∑RX8™...
No...never thought of that...I will thou...thanxx
Old Jul 6, 2007 | 11:01 PM
OL!z RX8's Avatar
«ΩLi√∑RX8™...
Thumbs up
I see...thats probably what Im doing...I guess I better take it to the dealer then...thanxxx
Old Jul 6, 2007 | 11:24 PM
read the owners manual... please..
and what is the psi in your tires?
it is that simple..
Old Jul 7, 2007 | 07:25 AM
CTrx8's Avatar
space for rent
it is that simple..
i would think it were that simple if the seatbelt light weren't also staying on. and why are people using the gauge on their pumps instead of using a separate one?
Old Jul 7, 2007 | 11:20 AM
shaunv74's Avatar
Power!!
A separate tire gauge is a very good idea. That and don't trust anyone to put the right air pressure in your tires. We just bought a new car from the dealer and the tires were at 45psi!!
Old Jul 9, 2007 | 05:31 PM
Strick9's Avatar
Same problem here...except I checked mine with 2 different gauges, both read the same amount, took it to the dealer and they told me i had 60psi?!?!?! umm....ok. So they "fixed" the problem.......yeah, right...it's still flashin.
Old Jul 9, 2007 | 11:13 PM
NgoRX8's Avatar
take it to another dealer...
drebbrnator
Dec 27, 2018 07:02 PM
05TiGr8Lady
Aug 27, 2015 07:31 PM
talonhart2
Aug 26, 2015 04:14 PM
akagc
Aug 11, 2015 07:07 PM
MolecularConcept
Jul 26, 2015 09:09 PM
