Need help, Exhaust Gasket question
Old Jun 25, 2007 | 09:23 AM
koaster's Avatar
Hi all, I have been a long time follower and have recently ran into a bit of trouble. I recently put on a Fujitsubo Cat-back exhaust. I am experiencing some exhaust leak from the cat to the B-midpipe.
I am wondering if I need a 3" donut gasket or can I use the stock one (or same size)? or do I even need one?
I bought it used so there was not one that came with the exhaust.
Your help would be greatly appreicated. Thank you.
Koaster
Old Jun 25, 2007 | 09:24 AM
mysql101's Avatar
you should reuse the stock gasket, unless it's falling apart. In which case just buy a replacement from your local dealer.
Old Jun 25, 2007 | 09:27 AM
koaster's Avatar
even thought the B-midpipe is 3" in diameter the stock sized gasket should be fine?
Warrior777
Jun 24, 2019 04:47 PM
RicerX1
Jan 11, 2016 05:59 PM
SupraG
Sep 21, 2015 12:09 AM
badinfluence
Aug 31, 2015 11:51 AM
yapakanichi
16
Jul 28, 2015 03:44 PM
