explain the rotary to me
Old Oct 1, 2003 | 11:59 PM
Turbo Matty P's Avatar
I know how the rotary engine works.....for the most part. What I'm curious about is the water pump. I know in my piston engine I have water channels that run throughout the block and head and provide passages for the coolant to pull the heat away. However, all I can see from every cut-away of the renesis (and rotories in general) is that the housing is very thin and water jackets aren't visable. Can someone explain the cooling system and lubrication system to me? I also noticed the oil pan is very shallow since there's not a crankshaft dipping into it. thanks.
Old Oct 2, 2003 | 10:17 AM
Speed Racer's Avatar
Certified track junky!!!
Turbo Matty P,
I think you'll find a lot of useful general rotary information at Rotary Engine Illustrated.
Old Oct 2, 2003 | 10:24 AM
wakeech's Avatar
mostly harmless
also check out the "engine tech info" thread.
fwiw, the water jackets in the rotary are inside the side and intermediate housing, and lubrication is through the oil bungs in the rotor housing, and through the e-shaft to the oil bearings and inside of the rotors (further cooling).
Hunterkelley24
Jun 14, 2022 08:32 AM
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
garryg
Australia/New Zealand Forum
Oct 1, 2015 04:54 PM
JCTaylor
Sep 30, 2015 07:31 PM
