ultimate emanage help!
Old Jun 22, 2007 | 01:47 PM
brad_93ls's Avatar
ok i just got my car tuned and in 7.5lbs of boost im seeing 11.7 on my a/f but i wondering what could the peak b with no boost or very little boost? or maybe does anyone have a good map for the ultimate ecu that seems to be doing the same psi with more hp. bc im only seeing 214 whp and i think it should be more..
Old Jun 22, 2007 | 01:50 PM
Kane's Avatar
214 WHP with 7.5 lbs of boost???? Do you have an auto?
Can you send me your log files from EMU with AFR in there?
Old Jun 22, 2007 | 01:51 PM
brad_93ls's Avatar
no its a 6 speed manual no im going back to the dyno shop in about an hour and a half and i can get them then
Old Jun 22, 2007 | 01:53 PM
Kane's Avatar
Cool, if you can get me the EMU log files, I'll see what you "should" be getting. It will be rough... but MM's tune at 6.09 lbs of boost was making 283 Crank HP at 6000 RPM-ish. THis is all off a a software app still in development so it may or may not be 100% accurate.
Old Jun 22, 2007 | 01:56 PM
mysql101's Avatar
if your coils or spark plugs are messed up, you're going to see reduced power too.
btw Kane, MM isn't running the greddy kit
brad_93ls's Avatar
ok yea i was thinking that the 214wheel power was verly low and it pissed me off a lil but i think the've got my car running to rich in the lower boost range
Old Jun 22, 2007 | 01:57 PM
Kane's Avatar
Good call, he has a diff turbo. But if his plugs were bad... would that not throw the AFR for a loop???? IE make it really rich?
Old Jun 22, 2007 | 02:02 PM
mysql101's Avatar
if you can post a scan of your old dyno, we might be able to tell you why you're making so low power.
brad_93ls's Avatar
just put new plugs on and had a misfire in the coils took it in and get 2 replaced
Old Jun 22, 2007 | 02:05 PM
brad_93ls's Avatar
well the dyno papers i have only show a graph with the greddy hp/tq and his hp/tq
Old Jun 22, 2007 | 02:17 PM
MazdaManiac's Avatar
1) Is this the Ultimate upgrade kit as GReddy ships it wired or a custom job?
2) Did you use an unlocked version of the GReddy map or a totally new one?
Send a copy of your map and any available logs and documentation.
Old Jun 22, 2007 | 02:22 PM
brad_93ls's Avatar
yea its the upgraded kit and i know the dyno shop made a map off of the greddy by tweeking it so i dont knwo what all was done ill get the map and the emu and repost them in about an hour
Old Jun 22, 2007 | 02:32 PM
The GReddy map comes locked, so they would have started from an unlocked version they got somewhere else or something completely different.
Seeing the map is critical to helping you out.
Old Jun 23, 2007 | 07:40 AM
tdiddy's Avatar
Finally Boosted!!!!!!!
airflow trick?
Old Jun 23, 2007 | 07:42 AM
Kane's Avatar
^^^ Huh?
Old Jun 23, 2007 | 07:59 AM
tdiddy's Avatar
Sounds to me like part of the problem might be the cat protection. MM's airflow trick might help but it is not going to get him up to 270-280 hp. Just have to wait to see the map.
Old Jun 23, 2007 | 08:42 AM
Kane's Avatar
Interesting...I will have to research the airflow trick thing.
Old Jun 23, 2007 | 09:00 AM
tdiddy's Avatar
https://www.rx8club.com/series-i-major-horsepower-upgrades-93/how-get-around-cat-preservation-120246/
Old Jun 23, 2007 | 05:09 PM
brad_93ls's Avatar
ok i have my greddy file but how do i transfer my greddy file with the maps on here so you can open it?
Old Jun 23, 2007 | 05:15 PM
brad_93ls's Avatar
and ive gutted my cat should i still make my airflow map look like that
Old Jun 23, 2007 | 06:44 PM
Gutted CAT won't matter.
Put the files in a ZIP file (right click => send to => compressed (zipped) folder) and post them up or e-mail them to me (link is on my site - click on my sig).
Old Jun 23, 2007 | 08:02 PM
brad_93ls's Avatar
ok i emailed it to you just to make it easier
Old Jun 23, 2007 | 08:28 PM
OK. I only got your "dynotune" map. I already have a copy of GReddy's shipped map, but I don't see any logs. If you have logs with injector output and A/F, that would be useful as a minimum.
That said, I hope you didn't pay much for this "dyno tune" because they didn't do much of anything.
In two, small areas of the sub-injector map, they pulled fuel and in two cells they added some.
Thats it.
No timing adjustments and no changes to the main injectors at all.
The GReddy map, as it is shipped, is utter crap. It has no fine tuning anywhere.
When they switched to the new wiring setup, they went with a really strange map and it is really lumpy and goes static above 6500 RPM.
Old Jun 23, 2007 | 08:32 PM
tdiddy's Avatar
the map...
File Type: zip
Old Jun 23, 2007 | 08:57 PM
brad_93ls's Avatar
see thats all i got i guess ima have to go back there b/c he did the dyno pulls with his program then he changed the cells on the I/J ADJ. Map2 and he said something about changing something with my timing on my laptop with greddys program
