Mazdaspeed Fog Light Brackets
Old Jun 14, 2007 | 08:47 AM
pondera's Avatar
Believer
I searched around but couldn't find what I was looking for. Does anyone have clear instructions (besides the ones that it comes with), possibly a DIY, on the MS fog light brackets install? There is just something about sawing parts that are attached to my new bumper in half that makes me nervous.
Old Jun 14, 2007 | 09:23 AM
edblor's Avatar
RX-8 Taker Arounder
Ouch!
Does not sound like a very clean install if you have to pull out a saw
I have not heard of having to do this, but perhaps some other members have.
G/L regardless
Ed
Old Jun 14, 2007 | 12:56 PM
jskup1's Avatar
The Chief
You don't have to cut anything while it's on the bumper. I'm assuming you are referring to the ducts and the mesh. You do a lot of "installing, marking, removing, then cutting. The included instructions really are as clear as can be. Read them over a few times before starting.
Old Jun 14, 2007 | 04:20 PM
kwescott's Avatar
One ball, corner pocket
He is referring to the oil cooler vents that direct air towards the oil coolers. They are very thin and easy to cut. The instructions are very thorough, as they make you test fit the brackets several times. I used a white out pen to mark the oil cooler ducts and cut with a hacksaw. Only advice, just make sure you leave as many mounting holes as possible so when you reattach the ducts to the bumper. Ive told many people that the bumper install is very simple (as you cna tell from the length of the installation guide).....however, the addition of the foglights more than doubled the install time (the installation guide for the foglight bracket is almost as long as the installation guide for the bumper).
Old Jun 14, 2007 | 08:04 PM
pondera's Avatar
Believer
I think the manual for the brackets is actually longer. I am going to take another stab at it this weekend.
Old Jun 14, 2007 | 09:33 PM
Kris's Avatar
Do you HAVE to have the cooler ducts to install the MS Brackets for the fog lights? I have a MS Replica front, it came with 2 parts that looks to be like the cooler ducts, but i tossed them because i didnt use them before.
let me know guys, as i just purchased the mounting brackets from Mazda.
Old Jun 14, 2007 | 09:45 PM
pondera's Avatar
Believer
I guess you don't HAVE to. I think it just helps direct the air.
Old Jun 14, 2007 | 10:17 PM
Kris's Avatar
Can anyone confirm this ^^^ before i proceed with install?
Old Jun 14, 2007 | 11:10 PM
kwescott's Avatar
yes, you do not have to have them
Old Jun 15, 2007 | 06:01 PM
RA-Eight's Avatar
Scuderia
I used a dremel, and worked like a charm. Bottom line is if you happen to mess up your cut, it won't be too noticeable.
Old Jun 16, 2007 | 07:27 PM
Kris's Avatar
I took the brackets to my body shop, they said 90 CDN to install it. I figured what the heck, might as well... It will save me some trouble since im installling them on a REPLICA MS front.
Will let you guys know how it turns out... I will be doing H11 LED's in the fogs.
RXFEVER
Aug 29, 2018 10:14 AM
RXFEVER
Sep 11, 2016 02:51 PM
yankeepicker
Sep 11, 2015 05:42 PM
wayloco
Sep 1, 2015 09:03 PM
