Need ECU connector pin diagram
Old Jun 5, 2007 | 11:46 AM
demon's Avatar
I am in need of the diagram which translates the below image to the actual pins on the ECU. If anyone has it I would be greatly appreciative!
Old Jun 5, 2007 | 12:16 PM
StealthTL's Avatar
Cool Diagram.....
That page is from the wiring diagram - the first twenty pages have all the ECU pinouts, what is the problem?
S
Old Jun 5, 2007 | 12:20 PM
demon's Avatar
The problem is that I do not have the first 20 pages
Old Jun 5, 2007 | 12:41 PM
SC-ed's Avatar
Thats from the service manual:
Hope it helps.
Attached Thumbnails Need ECU connector pin diagram-pcm-pinouts.jpg   Need ECU connector pin diagram-pcm-pin-out.jpg
Old Jun 5, 2007 | 12:46 PM
demon's Avatar
You rock, thanks so much!
Old Jun 5, 2007 | 01:18 PM
MazdaManiac's Avatar
I love people who can't/don't search. They warm my heart.
Old Jun 5, 2007 | 01:36 PM
demon's Avatar
Isn't it a little irrelevant to comment about it after the thread is basically over? I actually spent at least 30 minutes searching which is how I found the original diagram I posted.
Thanks to those who helped!
Old Jun 5, 2007 | 01:40 PM
Nah, not really. Especially in light of the info that is still missing from those diagrams as posted.
Old Jun 5, 2007 | 01:42 PM
demon's Avatar
All I needed was the pin locations for 5D 5O 5R and 5T (grounds) to get the tach working again after directly connecting the crank trigger to 2U and 2X.
Old Jun 5, 2007 | 02:00 PM
That'll be interesting since the ESS is so finicky.
Have you checked the float between the new way you have it wired and the existing wiring?
Old Nov 3, 2013 | 04:24 PM
kurorex's Avatar
Sorry to bump an old thread but does anyone know if the pin out above is the same for a UK spec 2004 6 speed 231 rx8?
Finding it a bit hard to find.
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
Quiggs321
Sep 30, 2015 05:34 PM
Learners_Permit
Sep 27, 2015 07:38 PM
You have already rated this thread Rating: Thread Rating: 1 votes, 4.00 average.
