What do you guys think of these wheels??
Old Jun 4, 2007 | 11:40 PM
pistolpen31's Avatar
Brian
http://www.wheelsnext.com/default.cf...color=GUNMETAL
the ones that are:
9 x 8(Front) +19x10(Rear)
245/35/19(Front) + 275/30/19(Rear)
for 1899.00 on a nordic green 8...
Old Jun 4, 2007 | 11:53 PM
chickenwafer's Avatar
Nope
they look heavy, not my style, but it's your money do what want with it
Old Jun 5, 2007 | 04:10 AM
deamicls's Avatar
Most people will advise against staggered wheel setup, me included. There's a reason why the car didn't come from the factory staggered.
Old Jun 5, 2007 | 05:39 AM
whoneedspistons's Avatar
the wheel is nice... they are very similar to the rh c7's (i think htat is the name of them)... nice you should find out the wieght of the wheel though
Old Jun 5, 2007 | 09:47 AM
Brian
is the weight of the wheel really an issue? cant i just get a chamber correction kit or something?
Thanks for your input.
Brian
Old Jun 5, 2007 | 10:15 AM
bruce_van's Avatar
Bruce Van
These wheels look really busy to me. Split spokes look the best on 5-6 spokes. 7 is way too much.
Old Jun 5, 2007 | 03:40 PM
kwescott's Avatar
One ball, corner pocket
nice wheel....good choice for your car.
Weight will make a difference in HP/performance for the car.
Old Jun 5, 2007 | 11:51 PM
Brian
deamicls said, "There's a reason why the car didn't come from the factory staggered."
whats the reason?? the only thing im worried about is eventually getting a negative chamber.. are there chamber correction kits??
Old Jun 6, 2007 | 12:00 AM
LionZoo's Avatar
road warrior
You need to read up. Negative camber to a point is good for you and Mazda's factory specs ask for negative camber, but too much is bad. Weight has no affect on camber and either does a staggered setup, but their detrimental effects on the RX-8's handling have been talked about time and time again on this forum.
Old Jun 6, 2007 | 12:20 AM
the bigger ? is why would you put a 275 on the rear of the stock car?
as to stagger. it is a sticky at the top of the page..
Old Jun 6, 2007 | 04:17 PM
kwescott's Avatar
You shouldn't have to worry about alignment/camber issue with new wheels...only when you change suspension components (spring/coilovers)....you would then need to go to an alignment shop to have things checked/adjusted.
Old Jun 6, 2007 | 04:30 PM
the rx8's factory suspension can sort of teeter totter as far as adding or correcting camber. No camber correction kits are needed.
Old Jun 6, 2007 | 04:54 PM
dmp's Avatar
dmp
RX8 and a Truk....
The polished lip ruins them; if they were all-black (how I like my women! ZING!), they'd be mucho betta.
Old Jun 6, 2007 | 05:49 PM
lazi's Avatar
drivelinestore.com
they dont look too bad
Old Jun 6, 2007 | 06:54 PM
MazdaJeff's Avatar
Brian
They look nice, but if your going to drop that kind of money you should get something that will imporve perfromance, at least in IMO.
Reducing unsprung weight is probably the best NA performance mod you can do for the rx-8.
escapedan
RX-8 Racing
58
Feb 10, 2020 06:11 PM
codesterb91
Nov 16, 2015 05:57 PM
olivierapex
RX-8 Racing
12
Sep 4, 2015 12:14 PM
MolsonB
Aug 18, 2015 08:42 PM
