Puking Coolant while Autocrossing?
Old Jun 4, 2007 | 12:57 PM
CosmosMpower's Avatar
1935 lbs. FTW!
I drove my RX-8 this weekend and it was pretty hot in the afternoon maybe 90 air temp. After my second lap on course (60 second with 70 mph section) I started to smell some coolant. Pulled into the pit, popped the hood and sure enough there were a few drops on the engine cover. Looked in the undertray inside the bumper and saw a few small pools of coolant, noticed the hose coming out of the overflow tank was wet.
Just wondering if any of you autox/track guys have ever seen the car puke out some coolant when it's too hot and you are driving hard. After cooling it down and driving home I didn't notice anything beyond that so I assume it's normal.
Old Jun 4, 2007 | 02:35 PM
search n00b
https://www.rx8club.com/series-i-trouble-shooting-95/coolant-overflow-issue-112059/
Old Jun 4, 2007 | 02:48 PM
StealthTL's Avatar
Cool Common....
Yes, it's quite common to smell a burp of anti-freeze when you're driving hard.
Not as benign as it sounds either - the puke blows down into the cooling fans and dribbles over a critical steering connection. Bad connections and poor grounds in this harness have been implicated in failure of the power steering in many cars (mine included). Fixed under warranty, but still......
I put a hard plastic tube from the rubber vent to the bottom of the rad.
S
Old Jun 5, 2007 | 02:57 AM
takahashi's Avatar
My power steering is on the other side haha.
I don't used to have it until recently. I guess I have to get a new radiator cap. I don't want to run higher pressure, it will just put pressure on the whole system. I will just change the stock one to a new one, new rubber .
Old Jun 6, 2007 | 07:41 AM
MrSuicideDoor's Avatar
clutch burner
that explains my power steering failure, there are so many power streering threads i never knew this was the reason
Old Jun 7, 2007 | 07:44 AM
1935 lbs. FTW!
Thanks for the replies I will find a way to re-route the short rubber tube away from the ps. I've autocrossed the car at 5-6 events and this wast he first time it happened.
hufflepuff
May 30, 2016 10:45 AM
Mane
Nov 20, 2015 12:16 PM
archon
Oct 1, 2015 06:08 AM
drlubell
Sep 26, 2015 11:58 PM
