New RX-8 drive: Heat & Noises
Old Sep 27, 2003 | 09:51 AM
juurdane's Avatar
Hello, I just bought a 6 speed MT w/ Grand Touring Package and after my first 40-miles drive I have the following comments and questions:
1.- After driving for a while, I started to feel a lot of heat around the shift stick area. My first impression was that the gear box was generating the heat, but actually most of the central panel was suffering from the same effect.
I stopped several times during my drive, and actually left the car running idle for about 3 min (w/ air conditioning on). Anyway, I made an stop at a restaurant for 45 min and when I came back the heat was still there.
Is this normal or was it a consecuence of the stops?
2.- There is a noise coming from below when you reverse from the parking lot and them make a right or left to start driving. Any hints on this?
3.- Sometimes, when the car is running idle some clicks and noises suddenly appear. Is that normal to rotary engines?
I will really appreciate your comments.
Regards. Juurdane
Old Sep 27, 2003 | 05:12 PM
Puppy1's Avatar
Pure Unadulterated Fun
1. Rotarties run hot. This is normal. No need to worry. That is why there are 2 oil coolers.
2. That "thump" you hear in the ABS doing a system check everytime you start out. No need to worry.
3. I don't think I've noticed what you describe here. Could just be metal peices expanding due to heat. Anybody else??
Happy motoring.
Old Sep 30, 2003 | 05:13 AM
jimbo_gixxer's Avatar
i also hear noise when turning out of my drive way from a complete stop. it sounds like the tire is rubbing the wheel well. has anyone else experienced this? my car has no mods to tires, rims (18") or suspension.
this noise seems to occur often. can you describe the ABS sound with more detail?
thanks!
jimbo
Old Sep 30, 2003 | 11:57 AM
GooOnYou's Avatar
Gig 'em
I've noticed the idle noises too and mines been running fine for 4000 miles.
Old Sep 30, 2003 | 12:04 PM
8_wannabe's Avatar
Go baby!
i hear voices when i drive...
Old Sep 30, 2003 | 03:08 PM
mikeb's Avatar
100% Italian
THe abs sound is pretty loud and its just one "thunk"
Old Oct 1, 2003 | 09:18 PM
khoney's Avatar
FX8TED on my RX-8
thanks!
jimbo
...sounds just like a tire rubbing the wheel well. And I'm not trying to be a smart-***, that's how it sounds to me too.
Old Oct 1, 2003 | 09:28 PM
syntrix's Avatar
I like cheese!
I get it when I pull out of my garage, and the driveway is just abit downhill. I back out, and when I first touch the brakes, it makes the noise, too. Exactly like a tire rubbing an inner plastic liner. It's from the front left.
There is 0 real rubbing, and once I'm going and flogging/drifting the car, everything is very tight.
I would say abs noise, but it's just a guess.
Old Oct 18, 2003 | 11:52 PM
arcnphat's Avatar
I have a rx8 with 1500 mile and I get a strange nosie and vibration from the engine.
Any one having similar problem please help.
arcnphat's Avatar
I meant to included that this only happens around 650 rpm
ktec
Jun 26, 2021 10:18 AM
rotor001
Jan 16, 2016 11:27 PM
Kanthinar
Dec 21, 2015 01:24 PM
Riot
Aug 27, 2015 04:01 PM
GrAfiX
Aug 24, 2015 08:08 AM
