Exhaust question....
Old May 17, 2007 | 11:24 AM
VASasha's Avatar
I have been looking at various exhausts and one thing keeps jumping out at me. Most of these exhausts start out as a 2.5-3" tube and then turn into a dual 2-2.5". What doesn't make sense to me is if they are only displacing (may not be the right word here) 3" of air to start, why do they need 5" (2x2.5) towards the end? Wouldn't dual 1.5" be sufficient? I understand that the rotary doesn't have backpressure issues but, besides the audial/visual factors, are there any other things that would require the reverse bottleneck?
Thanks in advance,
Sasha
Old May 17, 2007 | 11:30 AM
Keef's Avatar
the shit starter
hot is dense
cold is not
Old May 17, 2007 | 11:37 AM
VASasha's Avatar
isn't it the other way around? which is why a CAI works (in theory) since it pulls more cold air which is denser?
Old May 17, 2007 | 11:40 AM
BigRed's Avatar
w8nkel
you are right
Old May 17, 2007 | 12:19 PM
VASasha's Avatar
Originally Posted by BigRed
you are right
heh, which brings us back to our original question
Old May 17, 2007 | 02:55 PM
shaunv74's Avatar
Power!!
3" exhaust=14.13 square inches of x section
2.5" exhaust= 9.8 square inches of xsection
1.5" exhaust=3.5 square inches of xsection
If you split into pipes smaller than 2.5" then you start reducing your total xsectional area and ability to flow.
Old May 17, 2007 | 05:38 PM
grinn253's Avatar
Originally Posted by Keef
hot is dense
cold is not
debating whether this should be my new signature
Old May 17, 2007 | 05:49 PM
VASasha's Avatar
Thanks Shaun.
I am assuming that "xsection" is what I was referring to as "displacement"? How is it calculated? Just looking at the #'s it seems to be a curve.....and it seems that a 2" exhaust would be somewhere around 6.5-7?
Old May 17, 2007 | 06:56 PM
VASasha's Avatar
Water was the thing that was throwing me off, because I always thought that ice expanded.
Old May 17, 2007 | 07:21 PM
Keef's Avatar
the shit starter
hahaha, oops
Old May 17, 2007 | 08:23 PM
LabDad's Avatar
Doggie Style :)
Thanks Shaun.
You don't know how to calculate the area of a circle?
Old May 17, 2007 | 10:17 PM
BigRed's Avatar
w8nkel
it would be the area of tons of connected cylinders. pie(radius)squared times height. here it would be length. i guess if you knew how long it would be in addition to the pipes getting smaller or larger you could figure out the flow. I dont know much about this, but I am assuming equations that would make mucho sense. FYI, if you think hot air is better for the engine, dont put oil in your car, take the fan off, and put a heater in front of the engine. lol
Old May 17, 2007 | 10:57 PM
VASasha's Avatar
I guess I keep missing the obvious. Now that you said that it makes more sense. This is the kind of stuff I never thought I'd ever use again in high school.
Old May 17, 2007 | 11:10 PM
LabDad's Avatar
Doggie Style :)
Nope, just talking about cross sectional area here. No need to get too complicated unless you like going through a full Navier-Stokes equation. I don't ever want to do those calculations again.
Hunterkelley24
Jun 14, 2022 08:32 AM
arexatemate
Oct 28, 2019 08:16 AM
mdl0209
May 23, 2019 05:46 PM
Jb4ker96
Sep 27, 2015 10:06 PM
