Adjusting the Headlight
Old May 12, 2007 | 01:22 AM
Drugsrbad369's Avatar
DrugsRBAD
How exactly do you adjust the headlights? one of my headlights is centerd and the other is pointed at the ground, is there any way to adjust it?
Old May 12, 2007 | 07:25 AM
chrism's Avatar
Misfit Moderator TnC
if you have hid's it is automatic.....searching will yield you better results.....the clue i will give you is in the rear under the car
Old May 12, 2007 | 07:41 AM
mysql101's Avatar
you'll need a turbo headlight adjuster.
Old May 12, 2007 | 07:45 AM
BigRed's Avatar
w8nkel
my supercharged one works just fine! thank you very much
Old May 12, 2007 | 07:46 AM
mysql101's Avatar
without the bov, your lights are liable to just flop around when you hit bumps.
Old May 12, 2007 | 07:52 AM
BigRed's Avatar
w8nkel
the pulley secures it enough man. i dont like to have a whistle noise when im driving from the bov. btw, if youre having headlight troubles, pettit makes a really nice supercharger to fix it. if your interested in the turbo, greddy makes an OK one. decide which way you want to fix it, then go which route.
Old May 12, 2007 | 07:53 AM
mysql101's Avatar
I think he's already got the greddy, but it's installed backwards, so that's why the headlights are shining on the ground...
if you don't like the whistle, you can recirculate.
Old May 12, 2007 | 07:54 AM
BigRed's Avatar
w8nkel
that makes sense then. while he is at it he should change the hosings. they are not so good with greddy's kit. how could someone install it backwards?
Old May 12, 2007 | 07:57 AM
mysql101's Avatar
it's blowing air into the engine from the exhaust port, which is why it's smoking now...
Old May 12, 2007 | 07:59 AM
mysql101's Avatar
the nice thing about the turbo headlight adjuster is that you can get full headlight adjustment PSI at a very low rpm, and keep adjusting the headlights at that rate onwards... it's tied to engine load instead of rpm!
Old May 12, 2007 | 08:00 AM
BigRed's Avatar
w8nkel
which in turn signals the ecu to reduce the flux capacitor's capacity which then tells the other ecu to lower one side of the headlights in order to reduce the lopsided activity in which the turbo was installed incorrectly.
cased closed, im going to sue mazda for their poor gas mileage and low torque!
Old May 12, 2007 | 08:01 AM
mysql101's Avatar
That's why I buy 100% stainless steel vented brake lines for maximal performance. The 2% copper ones cause problems down the road, even though you're saving $3.50.
Old May 12, 2007 | 08:03 AM
BigRed's Avatar
w8nkel
which makes me wonder, if i buy new wheels and tires am I going to be a significantly faster driver on street roads?
Old May 12, 2007 | 08:14 AM
mysql101's Avatar
no, you should buy as skinny a tire as you can afford. Our cars come with traction control, so no need to wear out your tires early by using them for traction.
Old May 12, 2007 | 08:19 AM
BigRed's Avatar
w8nkel
that makes sense, because then we would have the lightest set of wheels and tires out there huh?
Old May 12, 2007 | 08:21 AM
DarkBrew's Avatar
Extraordinary Engineering
Yes
https://www.rx8club.com/attachment.p...chmentid=95957
Old May 12, 2007 | 08:44 AM
chrism's Avatar
you guys are both soooooooooooo off!.....you dont need to constantly adjust them...only when they are off...nitrous is the way to go
Old May 12, 2007 | 08:50 AM
BigRed's Avatar
w8nkel
but with a nitrous system you have to reconfigure the ecu to adjust the flux capacitor. in theory you are just getting the same thing done with many more steps
Old May 12, 2007 | 09:03 AM
chrism's Avatar
but its less stress on the bulbs
Old May 12, 2007 | 10:25 AM
BigRed's Avatar
w8nkel
does that mean i should switch from my s/c to this system you call "nitrous"?
Old May 12, 2007 | 01:37 PM
chrism's Avatar
absofriggenlutely
drlubell
Sep 26, 2015 11:58 PM
yankeepicker
Sep 11, 2015 05:42 PM
