Gage Top Panel - Integrated
Old May 10, 2007 | 01:02 PM
FlyingAce's Avatar
...Sunset Drive...
Hello
I have done a design out for the Gage Top Panel . Dimensions are taken from the PROSPORT Gage (are most gages dimensions similar by the way?). Also it will exactly replace the existing top panel, meaning it will have all the legs to fit into the slots. But making one is really costly from what i have found out.
Design pics will be posted here within a day or two after i have shrunk the images.
Old May 11, 2007 | 11:12 PM
sgrenesis's Avatar
THE GREAT WHITE
you can also look at re-amemiya and autocraft
Old May 11, 2007 | 11:49 PM
1stgen8's Avatar
Originally Posted by FlyingAce
Hello guys
I have been looking for a 3 gage top panel for my RX8 for some time, but never managed to get one, other than the mazdaspeed.
I have looked throught the forum and it seems there has been no closure of the project.
I have managed to get a design out for one. Dimensions are taken from the PROSPORT Gage (are most gages dimensions similar by the way?). Also it will exactly replace the existing top panel, meaning it will have all the legs to fit into the slots. But making one is really costly from what i have found out.
Is there anyone else still interested in this?
This one is not a full top panel but alot of ppl are using it. It is cheap but well worth the money.
https://www.rx8club.com/series-i-interior-audio-electronics-24/lotek-gauge-pod-110937/
Old May 12, 2007 | 12:11 AM
gfoo's Avatar
RE Amemiya, Autoexe, FEED can be sourced from MG.
Cheaper replicas can be sourced from other places.
Depends on what you want and your budget.
Another way is to get a 1-DIN top bracket, and buy the DEFI or Mazdaspeed 1-DIN 3-in-one gauge set
Old May 12, 2007 | 11:39 AM
FlyingAce's Avatar
...Sunset Drive...
hmm... So there are some out there besides the mazdaspeed, some of them do look good. Thank you for the links.
But i didnt know this initially and I badly want to have an integrated one after seeing the 350Z, so have proceeded to get a personalised design out.
Have yet to iron out all the design flaws. Once done and have adjusted the angles I will soon be prototyping it to see how well it fits into the existing slots. But the prototyping will be costly as hell!
Will post the design pics next, welcome any suggestion from the Bros to improve the design.
Old May 12, 2007 | 11:42 AM
FlyingAce's Avatar
...Sunset Drive...
Please do let me know if you have design suggestion pertaining to the pics.
Old May 13, 2007 | 08:27 AM
ngkenny's Avatar
stock standard
i like people who try to make things happen.....so i kinda support your efforts in making this work, however for this scenerio, what you are trying to produce is just a copy of the RE pod (could be a good copy....could be a bad copy...depends on your fabrication skills)....save the effort la.....don't make your life difficult.
https://www.rx8club.com/showthread.p...hlight=ngkenny
this is how the RE pod looks like installed.....looks like 'your' design right.
Old May 13, 2007 | 12:41 PM
FlyingAce's Avatar
...Sunset Drive...
Looks great! didnt know it has been out this long. How much did it cost, just the panel with/without installation. Or must it come including the Defi gages?
Old May 13, 2007 | 12:49 PM
Easy_E1's Avatar
What are "GAGES"?
Old May 13, 2007 | 07:55 PM
lohsk's Avatar
"Beng Your Ride"
Originally Posted by Easy_E1
What are "GAGES"?
Good point
Old May 14, 2007 | 02:19 PM
Rumboo's Avatar
Lurker
What are "GAGES"?
I thought you ought to know, since you yanks are experts at dropping superfluous 'u's from proper english words?
Old May 15, 2007 | 02:09 AM
mandotcom's Avatar
Hi Hi,
U interested in making the Gauge Pod? I have already made my 2nd pcs till date Still R&D...
Cheers!
MDC
Old May 15, 2007 | 06:43 AM
FlyingAce's Avatar
...Sunset Drive...
Mandotcom
I was reading your thread the last time, but it did not have a conclusion.
So is the panel almost ready? It will replace the existing panel? PM me the cost if possible. Been looking for this item for some time. Didnt really like those that are screw on, inserted etc.
Old May 15, 2007 | 07:09 AM
airspeed's Avatar
Velocity REight
Mandotcom
FlyingAce, did you use 3DSMax for the drawing? That's nice, but looks like most panel out in the market. How about trying to integrate a single DIN slot and 3 gauges together?
Old May 15, 2007 | 09:02 PM
FlyingAce's Avatar
...Sunset Drive...
Airspeed, what exactly do you mean? where would the Single DIN be? in front of the gages? Below the gages?
It should not be a problem to draw it, the biggest problem are the fastening legs under the panel.
What would the 1-DIN be used for by the way?
Old May 15, 2007 | 10:41 PM
mandotcom's Avatar
Hi FlyingAce,
I have make 2pcs..
1st moulded panel failed on fitment problems
2nd panel done, pass to "hellangel" to try out the fitment but he is Africa now.
I can finished this panel in either fiberglass or carbon fiber, BUT this material cant achive the fine details (for the screws and clips area) like the original. So to install, I am trying to use silicon instead of the original screwed on.
If you are interested, we can see how to improve on the fitment.
Cheers!
MDC
Old May 17, 2007 | 02:41 AM
airspeed's Avatar
Velocity REight
Yup, move the gauges up towards the windshield a bit and the single DIN would be in between the gauges and the opening for the LCD display.
The single DIN ould be for an aftermarket headunit or a flip out LCD headunit.
Old May 17, 2007 | 11:28 AM
FlyingAce's Avatar
...Sunset Drive...
Airspeed, i will see what i can do. Will do it when i have some time. But the gauges would be on a higher level to fit in the single DIN. Will probably be sitting on top of the Single DIN partially at least.
Old May 17, 2007 | 11:38 AM
FlyingAce's Avatar
...Sunset Drive...
Originally Posted by mandotcom
Hi FlyingAce,
I have make 2pcs..
Cheers!
MDC
MDC, so the panel is hand-molded using Fiberglass or CF?
I have enlisted the help of a friend to get the legs done based on the original panel, so that it will fit into the clip-on slots. It will be put into the drawing so i can do the prototype.
Since you already have a sample and have been working on it for some time, it will be helpful to improve on your product.
Jst4fun
Mar 5, 2021 07:16 PM
ShellDude
Oct 1, 2015 09:55 PM
alming1132
Sep 30, 2015 11:30 AM
jer2911
Sep 29, 2015 06:37 PM
