Fuel lines
Old May 7, 2007 | 10:17 AM
deanobeano's Avatar
Fuel lines
Hi ,to all , I know this will sound strange but which is the fuel intake line and where do i find it. Any help would be great.
cheers all deanobeano
Old May 7, 2007 | 10:31 AM
I dont really remember, is like the blue or red one. I could be wrong
Not sure. Its located right next to the engine.
Old May 7, 2007 | 10:43 AM
deanobeano's Avatar
Many thanks, will check that out.
thanks again.
deanobeano***
Old May 7, 2007 | 10:44 AM
eviltwinkie's Avatar
Umm...perhaps given your level of expertise...
DONT LOOK FOR EM...your first step had you any sense would have been to check the Mazda Tech Manual. There have been fires reported from people who have had work done to the fuel system and had subsequent leakage.
Mess with it if you want your car to turn into TOAST...
Did I say toast??
Old May 7, 2007 | 11:33 AM
dsmdriver's Avatar
Hopefully he's just trying to find it so he can clamp a magnet on it and get 50% more fuel efficiency and 38 more HP.
Old May 8, 2007 | 03:29 PM
imrtommy's Avatar
Need Rotary Engine!!!
Fuel is the red one not blue. They are next to each other near the dipstick. Also don't yank it out. Unclip the red ring. =)
Old May 8, 2007 | 04:06 PM
deanobeano's Avatar
Thanks, a lot imrtommy, thats all I wanted to know. *****
cheers deanobeano
Old May 8, 2007 | 05:07 PM
imrtommy's Avatar
Wait I forgot to mention to open the gas cap and wait for 20 mins to let the pressure drop or else gas will squirt all over you and the enginebay. Sorry forgot to mention that earlier.
Old May 8, 2007 | 05:37 PM
Go48's Avatar
That will NOT relieve the pressure in the fuel lines!!!
If you want to relieve the fuel line pressure, disconnect the fuel pump and run the engine until it quits. Consult the factory service manual. Fuel spraying around in the engine compartment is not something you want to see.
Old May 8, 2007 | 06:05 PM
imrtommy's Avatar
Uhm.... wait are you sure? I've taken the line in and out 3 times and the only time that happened was when I didn't open the cap.... yes I cleaned it ans let it dry for 2 days before I started driving again. =) sorry, I'm not saying that you're wrong and I'm right. I'm just saying that was my experience with it.
Old May 8, 2007 | 06:25 PM
Go48's Avatar
Here's what the factory service manual says.
yurcivicsux
192
Sep 12, 2017 10:54 PM
vapor2
Jul 9, 2016 07:35 AM
05rx8mazda
Nov 28, 2015 09:42 AM
