19x10 Rear rim tire question
Old May 1, 2007 | 03:27 PM
lowrdteg's Avatar
Who needs Cylinders
Which offset would i go with so the rim would tuck in the the wheel well +40? its a 265/30/19 tire.....
Old May 1, 2007 | 03:39 PM
Feras's Avatar
the Doctor
isnt 19x10 a little wide for 265?
Old May 1, 2007 | 03:42 PM
lowrdteg's Avatar
Who needs Cylinders
ok 275...what offset should i get so it tucks in the wheel well
Old May 1, 2007 | 04:53 PM
ChrisRX8PR's Avatar
13B-RE
You should look for an offset of 43-45mm. This would make it tuck in with a 265. 265 isnt small for 10", the ferrari f355 comes from the factory with that setup.
Chris
Old May 1, 2007 | 06:00 PM
40 - 50 mm should be fine with a 265, 38mm will clear with most 265s
I race on 265/35-18 Yokohama Advan Neova AD07 tires and am planning to upgrade from 9.5" @ 45mm to 10.5" @ 50mm all around in the future. This particular 265 is wider than any other brand 275 tire. We're only allowed to use up to 275 width tires. Kind of sucks because I'd die to run the 285/30-18 size instead.
fwiw 265/25.4 = 10.43"
https://www.rx8club.com/rx-8-racing-25/phat-76896/
Duren1
Mountain For Sale/Wanted
Jan 11, 2017 09:07 AM
jdzoom8
Aug 19, 2015 03:32 PM
akagc
Aug 11, 2015 07:07 PM
Brandonien
Jul 30, 2015 12:33 PM
MolecularConcept
Jul 26, 2015 09:09 PM
