One of the HID dies...
Old Apr 25, 2007 | 12:04 AM
james_bobby72's Avatar
The right HID dies yesterday...I brought it to mechanics and they ordered a new bulb from dealer(~$250...) and tried to change it.
After they changed it, STILL the same....
Other bulbs on right side are fine...
Does anyone know what's happening??!?!?!?
Is it the problem of wire harness?!?!?
Old Apr 25, 2007 | 01:59 AM
Cam's Avatar
Cam
this space for rent
May be the wiring harness. Its definetly electrical if the HID was changed and is still out. That tech has some diagnosing to do. The other bulbs would be fine cause they should be wired in parallel. Most likely an "open" circuit.
Which headlight is out? Low beam, high beam, both?
Ah, not that is matters. The tech needs to get into taking some voltage readings in the wirings to figure out just where the problem lies.
Old Apr 25, 2007 | 09:17 AM
you think it's expensive to do!?!?!?!
I don't want to go to dealer....the warranty has expired already
Old Apr 25, 2007 | 12:18 PM
Nubo's Avatar
Lubricious
The HID uses a ballast that supplies something like 25,000 or 50,000 volt startup pulse. Don't mess with it if you don't know what you're doing.
Old Apr 25, 2007 | 04:55 PM
do you think it's the problem with the battery or fuse?!
Old Apr 26, 2007 | 12:27 AM
Cam's Avatar
Cam
this space for rent
Correct. 25 kV. You dont what to try to do drop test across the headlight with that much voltage unless you know what youre doing.
However, since his headlight was replaced with a new headlight, and it still didnt work you can rule out the headlight as the problem.
Cam's Avatar
Cam
this space for rent
Check for a blown fuse, but I doubt it.
Battery, no, not the problem.
Old Nov 1, 2008 | 07:30 AM
mikko79's Avatar
Any updates on this problem?
I have the same problem. My right headlight (low beam HID) started to flicker couple weeks ago and then it totally died. I changed a new HID bulb and it worked fine. Now few days ago the buld died again!? It was a cheap "brand-x" bulb, so i bought a new philips bulb, same as the original.
So now there's a new bulb, but no light. I've checked the fuses also and they are ok.
Is it some relay or groundig problem? All other lights works fine. Only the right lowbeam is out.
I have read something about "ballast" problem. Can anyone explain to me how to diagnose the ballast problem?
Thanks for any help, sorry about my bad english.
Old Sep 7, 2012 | 06:49 PM
dhicks's Avatar
My son's RX8 is experiencing the same problem. Passenger side lo beam out, new bulb and still not working. Fuse is good. Will check the ballast tomorrow. Hope we figure this out soon.
Anyone with suggestions?
Old Sep 8, 2012 | 06:37 PM
j9fd3s's Avatar
its pretty simple, its either the bulb, ballast, fuse or the wires in between...
Old Sep 9, 2012 | 09:13 AM
dhicks's Avatar
How do I check the ballast to see if it is good?
Old Sep 9, 2012 | 11:43 AM
j9fd3s's Avatar
i've never done it on the 8, but usually its easiest to plug in a known working one. you have to be a little careful, you can test that the ballast gets 12V power, but the voltage to the bulb is really high, so its a little dangerous.
i know doing this ON the Rx8 is hard, cause its not really easy to get at the bulbs
Old Sep 11, 2012 | 10:11 PM
Mint87rx7's Avatar
Ok HID lights are actually impossible to diagnose electrically past the 12v supply and ground. You need to see the voltage spike on an oscilloscope to identify the problem and no scope under $30k is able to test at those voltages (cant get an inductive pickup on them like a plug wire). The only way to diagnose what part has failed is pull everything apart and swap one part at a time from side to side and see what part the problem moves with. If you by chance have an intermittent problem on both sides there is no way to know what is wrong unless you just replace every component past the primary voltage (bulbs, ballast, resistors, coils).
dont worry about getting zapped on these unless your playing with stuff with the lights on, its not like power lines. if your headlights are off there is nothing there to hurt you so just move parts around.
arexatemate
Oct 9, 2015 06:23 PM
wayloco
Sep 1, 2015 09:03 PM
beastman_5
Aug 30, 2015 10:22 AM
