DIY: Remove/Replace Rear Combination Light(Tail Light)
Old Apr 24, 2007 | 10:04 AM
Update : April 18, 2008
Im adding Q&A to all my DIY. Including this one.
1. What is this DIY all about ?
- This DIY is to show you how to take your rear combination light(s) out.
2. Why would I want to take it out?
- Well, this is one of the RX-8's *known* problem. Depends on how dusty your area is, dirt will build around the gasket area, eventually, the dirt will block the water flow completely, then your Rear combination light will collect all the water and turn itself into a fish tank. the only way to prevent this from happening is to *take it out, and clean it once in a while*. This is not really a RX-8 only problem, I've seen A LOT of cars out there with the same problem. meh. We're not alone!
3. What kind of tools do I need?
- 10 mm socket or wrench.
- working arms and hands.
- Some time, maybe an hour or so. should be less.
- Glove is NOT required, but if you are afraid of getting hurt in the process. You can always get a pair of those *working* gloves that has red paint on one side. For like what couple a buck or 2 a pair.
4. Do I need to watch out for anything ?
- Well, there is a chance that you might break some plastic in the process. You might cut yourself too, so just becareful.
Photos are based on the right side tail light, its the same as the left side, just follow the order.
This is what it looks like
then u'll need to take these plastic fasteners out, I circle them in red
You'll need to take the center piece out before you have access to the light, so just do the same thing to the other side, take the top and bottom of the fasteners out.
then, pull this piece straight UP
Attached Thumbnails DIY: Remove/Replace Rear Combination Light(Tail Light)-dsc02785s.jpg   DIY: Remove/Replace Rear Combination Light(Tail Light)-dsc02786mod.jpg   DIY: Remove/Replace Rear Combination Light(Tail Light)-dsc02787s.jpg   DIY: Remove/Replace Rear Combination Light(Tail Light)-dsc02788s.jpg   DIY: Remove/Replace Rear Combination Light(Tail Light)-dsc02789s.jpg
Old Apr 28, 2007 | 01:25 AM
Now, this is the fun part, unplug the 4 plugs (circle in red), you dont really have to mark them cuz I think it only goes in one way, they have diff colors on them, so just remember which one goes to which. Then take 2 bolts (in Blue Circle) out, I think its 8mm or 10mm in size Im not 100% sure. After the above, remember there is a little plastic tab(hook, orange circle) right UNDER the middle light, when you try to pull the light out, remember to push this tab a bit, then the whole tail light should slid right out
Notice : The one that has been covered by foam, look closely to the connector u will see a little tab, just squeeze it hard and it will come out.
The bulbs still attached to it ? just turn it and it will come out.
After that you will see a piece of grey looking gasket. if you're out of warranty and want to save a few bucks, you can clean the gasket with soap and water, to dry it, you can blow dry it, but do NOT heat it, its going to melt, and it will not be funny.
or replace it with revised gasket from Mazda, but it will NOT FIX THIS PROBLEM !
After everything dries up, just put them back in reverse order.
Update:
- If you want it to dry FAST, you can either put it on a stack of old newspaper, news paper love moisture!
- Or you can put it on Air purifier like I did.
- Try to do this on a Sunny and Low Humility Day. It helps to dry it a lot faster.
- If you see Water spot in the lights, you can pour some *white* vinegar into the light, move it around. then just dry it with the method above.
- Remember, do NOT force anything. If its stuck somewhere, you probably forgot to take something out. Just be easy, and say good bye to condensation ! (for a while ...)
Attached Thumbnails DIY: Remove/Replace Rear Combination Light(Tail Light)-dsc02790mod.jpg
Old Apr 28, 2007 | 01:06 PM
Mortal Moxie's Avatar
Taylor not Tyler
Too add to this DIY I have some information of my own.
Like many 8 owners I've also run into the condensation issue on multiple occasions.
This time I got tired of going to Mazda to get it fixed. The closest Mazda service center is not very close to me at all and I work a lot, so it's not convenient for me.
I decided to follow nycgps's DIY. I got up to the point where I had the taillight completely out of the car. I looked over it, shook it, tilted it, and I noticed theres no easy way to get the water out of it.
So I kept tilting it on different angle to see how the water moves inside it and where it goes.
I was able to completely dry out my tailight by myself without having to go to Mazda again.
1: Follow nycgps's DIY.
2: While you have the taillight out of the car, remove all 3 bulbs, and place them in a safe spot. Like all bulbs they should be handled with care. Be sure to not get any grease prints on the glass. While they are not like headlights that run all the time, grease can still cause the bulbs to shatter.
3: Get a shop vac or borrow one from a friend.
4: Attach the smallest end connector to the end of the hose on the shop vac so that the suction from the vacuum is extremely concentrated.
5: Turn on the vac, and stick the hose into or over the hole for each bulb. The suction from the vac may not pull water out of the light directly, but it will get air circulating in there like crazy.
6: I let mine run on each bulb hole (or outlet) for 10 minutes a piece.
It helps to tilt the tailight while you have the hose sucking air out of it, it moves the water around and helps spread it out. See what technique works best for you.
I just did it myself this morning and it worked really well. We will see how long it lasts, but I appear to have gotten all the water and condensation out of the light.
If you have any doubt at all in your mind about trying this, then don't do it. It worked for me, and it may work for you, but I don't know right off the bat if this can cause any major issues or malfunctions.
Thanks,
Old Apr 28, 2007 | 06:30 PM
I sent ya a PM, but I guess I will add some follow up here
How I dried my tail light ? I left it on top of my air purifier, turn it up high for 2-3 hours. completely dry.
I thought about the vacuum idea before, but I hate vacuum cleaner sound (loud as hell), so I just did the air purifier trick, it dried my light, and made my room's air cleaner
Old Apr 28, 2007 | 07:41 PM
loco4rx8's Avatar
BSG 75
I tried this, but there was one wire I never could figure out how to get loose from the tail light. It didn't appear to have any connector.
In nycgps's picture of the wiring, it's the wire closest to the connector you have circled in red at the top of the picture.
Can someone help? Thanks.
Old Apr 28, 2007 | 11:06 PM
You mean this one ?
You can take it out by squeezing the connector, its covered in foam.
Attached Thumbnails DIY: Remove/Replace Rear Combination Light(Tail Light)-some.jpg
Old Apr 29, 2007 | 08:24 AM
Taylor not Tyler
Read what nycgps said. The last connector is covered in foam. It looks like from his pic that you can see the white clip coming out from under the foam in his car. I'm willing to bed that the foam piece is completely covering the white clip on yours, so it wouldn't make it apparent that there's a clip under there at all.
Carefully slide the foam off to the side, and unclip it like all the other 3 clips. Then bam, you're done you can slide that puppy out.
Old Apr 29, 2007 | 09:24 AM
CoMBo8's Avatar
My 8 is Sexy!
it takes me some times to take out the tail light at first time without any DIY guide, but after that i only need like 5 mins to take out the light the next time. easy job. good guide.
Old Apr 29, 2007 | 12:41 PM
loco4rx8's Avatar
BSG 75
Yes, it was covered in foam. Thanks guys, I appreciate the help!
Old Aug 24, 2007 | 06:15 PM
PSUGreySreet's Avatar
This was a great DIY. My car is 2,000 miles out of warranty and the nearest dealer is 20 miles from my house, so it was ridiculously easy following the instructions to do it myself. Thanks guys!
Old Dec 22, 2007 | 01:11 AM
bigireland's Avatar
Man, We Ain't Found Sh*t!
just got finished.. was gonna take before and after pics but the dealership took it upon themselves to drill a small hole in my drivers side tail light to let the water out.. bastards stole my thunder! but regardless, thanks for the DIY..
Old Jan 3, 2008 | 12:47 AM
dimigon's Avatar
Is there anywhere I can order new gaskets from, besides going through the dealer?
Old Jan 23, 2008 | 09:16 AM
Sushi's Avatar
I need to do this myself. I have a few questions though. I have never done this sort of thing, but would my gaskets on my 04 still be ok if I washed them? Also To get the condensation out of the light do you need to drain it, or I see people using blow dryers, but where do you aim the air to get it in there?
Old Jan 23, 2008 | 12:48 PM
HiTMaNN's Avatar
RX-8s Official Cool Guy
YOU ARE A GENIUS NY!!! My warranty is over and I used to shutter at seeing my fish bowl. I did this DIY this morning and I am going to put back the lights. I ripped my knuckles while doing the DIY but thats because my hands are fat and I was getting impatient But know that I know it is going to so easy to take it apart. I didn't have a Air Purifer so I just kept using my shop vac and after about 15 minutes were tail light the water was all gone.
Old Jan 23, 2008 | 01:06 PM
Your gasket will be fine. put some glue around the gasket after u're done.
I have the new and so called *will fix the issue* gasket and it still fog up
You can use Blow dryers, but I found that it *often* takes too long to dry it completely. so I just left it on my air purifier then I go have lunch or whatever, when I come back it should be dry.
If you want to get rid of those water spot. when dried, give it some windex and shake it around, and dry it again.
Old Jan 23, 2008 | 02:38 PM
HiTMaNN's Avatar
If I glue the gasket on and I remove it later (if it happens again) I will not run into any problems right?
Just asking because I am about to put my tail lights back on.
Old Jan 24, 2008 | 07:10 AM
Sushi's Avatar
Good Question, also what glue should I use? Any specific type?
Old Jan 24, 2008 | 03:26 PM
slavearm's Avatar
Boost Junkie
I wouldn't glue it, I would use a nice silicone lube or grease.
Old Jan 25, 2008 | 07:09 AM
Sushi's Avatar
Can anyone tell me what they use to put the gasket back on? Do I glue it or use some other adhesive. What did you guys who have done this already use? I just want to pick up the right stuff today so I can try this tonight.
Old Jan 25, 2008 | 01:04 PM
Sushi's Avatar
Actually, will a 2008 taillight work on an 08? I figured it would but wanted to ask before I purchased, I was thinking about just getting some new ones off of ebay, and just installing them. Should they come with the gaskett to install?
Old Jan 27, 2008 | 09:05 AM
Sushi's Avatar
Hate to bump, but I really need to know before I order. If I get the full set of lights from a guy with a 2008, is the gasket already on the lights normally?
Old Jan 27, 2008 | 02:56 PM
slavearm's Avatar
Boost Junkie
I just did mine with the new gasket... you don't need any sealant. The new one is so thick, nothing will get through. It comes with some double sided tape already attached. It takes like 30 seconds to attach.
Old Jan 27, 2008 | 03:46 PM
rled's Avatar
5Picker
I bought the so called new an improved gasket from Mazda. Cost me 44 dollars. I removed the tail light assy. ,stuck an air hose in and dried it all out. I put a little clear silicone on the top edge where the gasket contacts the rear body panel, re-installed and damn, next day , fogged up again. The gasket was obviously a waste of money. I guess the next thing is drill the holes,. What a bunch of crap! Mazda said **** on ya, you are 2k out of warranty. I'm gonna look for cracks on the tailight next time I remove it.
I noticed that the light sockets do not have gaskets on them like some other cars I have had. Does anyone else have gaskets on theirs?
Old Jan 27, 2008 | 03:59 PM
slavearm's Avatar
Boost Junkie
Mine do not have gaskets on them.
Old Jan 27, 2008 | 04:48 PM
HiTMaNN's Avatar
They all should the gasket are the rubber pieces which are put on your tail light with double sticky tape. YOu have to carefully rip it off.
