Changing to wider tires.. need advice
Old Sep 23, 2003 | 01:24 PM
Squidward's Avatar
Bottom feeder
Question:
What is the maximum tire size My RX-8 MT's 18" rims can handle before I start running into problems (such as rubbing, etc)..
anyway, if there is anyone out there with knowledge in this area, please elaborate on this... How far can you go in terms of only changing the tire, on a typical wheel...
I'm looking to increase the width of the tire, mainly for visual kicks.. something like 235/40 or 45's would be great...
Old Sep 23, 2003 | 05:36 PM
wakeech's Avatar
mostly harmless
you mean SIDE WALL HEIGHT (or just "height")??
*shrug* measure and see how big you can go.
Old Sep 23, 2003 | 08:58 PM
TybeeRX-8's Avatar
I REALLY LOVE THIS CAR!
Take a look at this thread:
http://www.rx8forum.com/showthread.p...threadid=11421
Old Sep 23, 2003 | 09:36 PM
Squidward's Avatar
Bottom feeder
Wakeesh, I mean the width of the tire, primarily.
I don't want to replace my rims, just want to add new thicker tires.. How wide can the the the current OEM 18's take?
235 is okay Ithink, how about 265? 300??
Old Sep 23, 2003 | 10:28 PM
syntrix's Avatar
I like cheese!
The stock 18's are 18x8, so a 245/40/18 will fit on there no problem, but it's like a 1% difference on the speedo conversion. Also that size has a LOT more options than the stock 225/45/18.
I just ordered better tires for the stock rims, so I just went through all the research.
Old Sep 24, 2003 | 01:37 AM
mikeb's Avatar
100% Italian
someone put 275 in the back
Old Sep 24, 2003 | 01:39 AM
Good Duck's Avatar
No more parachute
syntrix,
Which tires did you finally choose?
Old Sep 24, 2003 | 03:50 AM
wakeech's Avatar
mostly harmless
Re: Changing to wider tires.. need advice
ah ha... so you did mean width... what really threw me was this:
...which lead me to believe you wanted vertically wider tyres
Old Sep 24, 2003 | 04:43 AM
Kev's Avatar
Kev
[rapidus octus]
that's right, vertically wider - for the tardis :D
Old Sep 24, 2003 | 12:33 PM
wakeech's Avatar
mostly harmless
Originally posted by Kev
the tardis :D
coolest sci-fi concept 3vAr...
*whistles BBC Radio Orchestra's Dr.Who theme*
Old Sep 24, 2003 | 02:14 PM
Squidward's Avatar
Bottom feeder
I how about Potenza RE040's that are
255/45/18
I looked on the Bridgestone website to find out the allowable minimum rim width is 8 inches.
so it should be okay right???
are there any potential problems here?
Old Sep 25, 2003 | 02:35 PM
Vaillant's Avatar
RX-VIII
This might help you out...you can figure out how much of a change in the overall diameter different tire and wheel sizes could have. This is important in order to keep the speedometer accurate...
http://www.miata.net/garage/tirecalc.html
- Matt
Old Sep 25, 2003 | 09:08 PM
syntrix's Avatar
I like cheese!
Or if accurate speedos' are your requirement AND you want to change the diameter, this might work on the 8:
http://www.blackrobotics.com/
Works on other cars, and I have one on my geared 03 R6
LB2739
Jul 9, 2019 02:25 AM
Irvinb16
Sep 11, 2015 10:27 PM
TJSiegrist
Sep 10, 2015 09:29 AM
Anthony Kevin
Sep 7, 2015 07:36 PM
wayloco
Sep 1, 2015 09:03 PM
