Drilled & slotted brake rotors
Old Sep 22, 2003 | 02:45 PM
foodiedave's Avatar
Looks like I'm the first kid on my block with drilled & slotted brake rotors for my sweet little 8!
Hmm...tried to post an image...no joy...I'll try again...
Old Sep 22, 2003 | 02:51 PM
foodiedave's Avatar
Here's another attempt at posting a picture of the new rotors...
foodiedave's Avatar
Cool. OK, here's another one...
Old Sep 22, 2003 | 02:54 PM
wakeech's Avatar
mostly harmless
i gather you've shot the discs on your rear left.
whose brake discs are these??
Old Sep 22, 2003 | 03:04 PM
foodiedave's Avatar
Correct. The others were done as well, but they all look pretty much the same.
They were done by Paul at Rotorsport in Santa Clara, CA. He's got a barebones web site under construction at www.renesisracing.com.
Old Sep 22, 2003 | 05:43 PM
r0tor's Avatar
why do your rims have holes in them!?!?
nice brakes BTW
Old Sep 22, 2003 | 05:54 PM
r0tor's Avatar
w0w... my rims have holes t00.... when did those get there!!!!
...damn carpenter bees probably :p
Old Sep 22, 2003 | 06:07 PM
foodiedave's Avatar
Damn Japanese alloy-eating carpenter bees, no doubt!
Old Sep 22, 2003 | 07:19 PM
spdspappy's Avatar
Too funny! LOL!!!
Old Sep 22, 2003 | 07:44 PM
mikeb's Avatar
100% Italian
nice
what was the cost if you dont mind. I know a shop in anaheim and they said they would drill my stock ones for 300.
Mazdatrix 8 has slotted and drilled rotors too
Old Sep 23, 2003 | 01:31 AM
foodiedave's Avatar
Originally posted by mikeb
nice
Thanks.
I got "special consideration" for demoing their prototype.
I'd rather not mention prices and risk incurring the wrath of Elara the Mod. Their web site (Renesis Racing) has more info...
All four? That sounds pretty decent. Just be sure they know what they're doing. Paul, who did mine, pointed out to me that it's important to design the drill pattern carefully to avoid weakening the ribs between the rotor plates.
Cool! The more, the merrier!
Old Sep 23, 2003 | 01:38 AM
wakeech's Avatar
mostly harmless
wait, what?? these are just your stock rotors with holes drilled and slots cut into them?? :o hmm... i dunno about that, unless all you cared about was getting the look.
Old Sep 23, 2003 | 09:57 AM
Evolv's Avatar
I'm with wakeech on this one. I'll wait for production ribbed and drilled rotors to be available. By that time my originals should need replacing :D
Old Sep 23, 2003 | 11:01 AM
ninedeep's Avatar
Thats funny!!!:D :D :D
Old Sep 23, 2003 | 12:33 PM
mikeb's Avatar
100% Italian
I dont want them drilled just for looks
So by taking the stock ones and drilling them is pointless?
Old Sep 23, 2003 | 01:22 PM
mmm's Avatar
mmm
There's also a short-shifter kit at that site -- 30% shorter thow than stock. Interesting.
Old Sep 23, 2003 | 01:32 PM
Evolv's Avatar
WOW like the throw wasn't short enough already ..........
Old Sep 23, 2003 | 01:59 PM
Gord96BRG's Avatar
Re: Drilled & slotted brake rotors
Was there a problem with the OEM rotors that you're trying to fix by 'upgrading'? All the reviews seem to indicate that the RX-8 brakes are among the strongest on the market, with no fade....
Re drilling stock rotors - it's pretty much guaranteed that if you drive those hard, like on a track, that you'll get cracks and premature failure in them. Even cast hole rotors can have problems with the stress concentrations and heat cycling - drilled rotors are a recipe for disaster.
Regards,
Gordon
Old Sep 23, 2003 | 02:37 PM
foodiedave's Avatar
Re: Re: Drilled & slotted brake rotors
No, actually, I got them partly as a demo favor for the guy who manufactures them, and partly because I figured the extra cooling effect (however great) couldn't hurt.
And yes, they look kinda cool, too.
I have no plans to drive them hard on a track, and the drill pattern has been carefully designed to avoid hitting any of the ribs between the rotor plates (as I mentioned above).
Whoa, might want to put the brakes on that hyperbole before it spins outta control.
Old Sep 23, 2003 | 03:48 PM
renesis_racing's Avatar
Virtually every drilled and slotted "sport" rotor (aka street performance rotor) is based on a stock production brake rotor, mostly aftermarket, and in this particular application since there are no aftermarket replacement rotors yet available, are based on stock Mazda OEM pieces.
Every rotor you see for sale on Ebay or elsewhere is based on an original replacement or aftermarket replacement.
Yes, these rotors are very good looking, but they are absolutely functional as well. Everyone knows the theory behind drilling and slotting brake rotors. These rotors are carefully designed and machined to retain full rotor integrity while providing the best features of drilling and slotting. This was done by carefully machining the holes such that they do not penetrate the cooling vanes and properly chamfering them to prevent cracking.
Old Sep 23, 2003 | 04:36 PM
mikeb's Avatar
100% Italian
nice first post
Old Sep 23, 2003 | 05:29 PM
wakeech's Avatar
mostly harmless
ah, then i suppose you must as well. enlighten us ingorami who don't... is it soley to decrease the conductive mass of the rotor to increase the impact of heat cycling stress, or also to decrease the area of contact between rotor and pad??
regardless of your marketting rhetoric here, the truth is that cutting or else modifying a CAST metal piece such as these brake rotors wreaks havoc with the naturally formed atomic matrix, hence weakening it. despite your obvious skil and thought in doing so, drilling cast brake rotors has been proven to be counter productive in seeking high-performance.
that aside, they do look cool as hell, but are like the "real deal" only in look. sorry to be so cinical, but i'm tired of people (not necessarily you) trying to pass off rice as high performance
Old Sep 23, 2003 | 08:07 PM
mikeb's Avatar
100% Italian
wakeech
is that a pic of you in your avatar
Old Sep 24, 2003 | 03:42 AM
wakeech's Avatar
mostly harmless
wakeech
the one and only... lemme guess, you look like me??
Old Sep 24, 2003 | 04:26 AM
Efini 8's Avatar
no pistons!
i'll let u guys in on a secret... I have an entire real big brake kit coming in - the 1st one in the states to get them actually . I'll post pics after its installed.
