Trec-FW throttle electronic control
Old Apr 13, 2007 | 11:39 AM
csl's Avatar
csl
Anyone knows how to change the setting? I don't know how to read japanese. Thanks
http://www.siecle.co.jp/match/mu%20trec%20fw.pdf#search='trecfw%20%E3%83%9E%E3%8 %203%8B%E3%83%A5%E3%82%A2%E3%83%AB'
Old Apr 13, 2007 | 12:49 PM
rotarygod's Avatar
Japan8 can translate it.
Is this for the RX-8?
Old Apr 14, 2007 | 06:05 AM
csl's Avatar
csl
Yes. I found it in my RX8 engine bay (imported from Jap as recond unit)
Old Apr 14, 2007 | 02:08 PM
brillo's Avatar
Go Texas Longhorns!
what does this do? does it allow you to change the DBW settings?
Old Apr 14, 2007 | 04:03 PM
cajunrx8's Avatar
Rotary Crawfish
It is a speed limiting device cutoff for JDM cars to allow full speed of car.
Old Apr 14, 2007 | 04:08 PM
cajunrx8's Avatar
Rotary Crawfish
Oh I searched around the site some more and they also sell a module to controll shift points and speed s of a CVT equipped car.
CVT being a constantlly variable transmission.
Old Apr 15, 2007 | 01:01 PM
csl's Avatar
csl
Is that true? I thought it was just a device to change the throttle respond faster for those drive-by-wire car. Will find a chance to check out the top speed.
Old Apr 15, 2007 | 04:19 PM
cajunrx8's Avatar
Rotary Crawfish
Well it may do more than that, I posted what I could get out of the broken engrish Goggle provided in the translation.
Old Apr 17, 2007 | 03:21 PM
csl's Avatar
csl
Just tested my car. I'm not sure the top speedat the beginning, but can go 10k rpm. But then again, after change the battery, Can't up anymore. Max 9.5k only. I let go at 187km/h due to the road uneven and caused the car so bumpy and move left and right..
How I change the battery:
1. remove both + and - then took out the old battery.
2. Put a new battery on. Connect the + and -.
After that, found the DSC light and car slipped light on. After off the engine, DSC gone. And after run for some distance, off the engine and the car slipping light off as well.
http://www.siecle.co.jp/match/mu%20trec%20at.pdf
cliffkemp
Dec 24, 2024 10:48 AM
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
D13
Oct 1, 2015 07:55 AM
urbanvoodoo
Sep 30, 2015 12:41 AM
pjwermuth
Sep 28, 2015 11:36 PM
