Question about exhaust
Old Apr 7, 2007 | 12:26 PM
tajabaho1's Avatar
Destroying Threads
Hi, after reading some threads.......I'm totally confused.......
from what my little brain can deduce
exhaust = the muffler thinging and a pipe..........
but then theres a catalytic converter
so I want to change my exhaust.....but still be street legal and pass emissions
that means that the exhausts that are like 500-600 are only for the muffler and a pipe and the catalytic converter would be stock right?
so if then I hear that if you take out the cat, it be much faster......but then it wouldn't be street legal........so how do you make it street legal?
someone please explain to me....im totally confused
Old Apr 7, 2007 | 12:35 PM
staticlag's Avatar
The Professor
if you remove any part of the factory emissions system, the "cat" or otherwise, it is illegal. There is no way to get around this.
Muffler + connecting pipe $500-$1000
hi flow cat or delete pipe $300-$500
headers ~$1000
so probably in the range of $2000 if you wanted a "full exhaust" system.
Old Apr 7, 2007 | 12:39 PM
staticlag's Avatar
The Professor
But, a lot of people buy whatever they want, and when it comes time for a emissions check they swap back in their stock parts.
Old Apr 8, 2007 | 12:33 AM
N rider89's Avatar
^NieL
what he said, also keep in mind no cat=loud
Old Apr 8, 2007 | 12:41 AM
BoosTED's Avatar
Unless a person puts a nice resonator in the midpipe.
Old Apr 8, 2007 | 12:54 AM
Fanman's Avatar
And stinky.
Some states don't do a visual inspection, they just stick a sniffer in your tailpipe. So a hi-flow cat unit will allow you to pass. In Cali. they also do a visual inspection, but most mom & pop gas stations that are "smog test certified" won't know what a stock cat looks like.
Old Apr 8, 2007 | 08:08 PM
tajabaho1's Avatar
Destroying Threads
I see, so like when they sell stuff like B&B exhaust system, they are only talking about the muffler and midpipe right?
Old Apr 8, 2007 | 08:13 PM
N rider89's Avatar
^NieL
^no, that would be Just muffler and connecter pipe i believe.
Old Apr 8, 2007 | 08:30 PM
tajabaho1's Avatar
Destroying Threads
so what is a mid pipe then? and what can I change to get the most performance without screwing up emissions?
Old Apr 8, 2007 | 09:56 PM
d j's Avatar
d j
hukbong himpapawid
mid pipe would be the pipe that connects the cat back to the header minus the cat
Old Jan 19, 2008 | 09:52 PM
superdon2's Avatar
Now watch me yuuuuaaaaaa!
headers ~$1000
how will they know that i changed my cat-back exhaust?? because it's a bit louder? if so, why aren't lamborghinis being pulled-over because of their loud stock exhausts?
im confused..
Old Jan 19, 2008 | 09:59 PM
staticlag's Avatar
The Professor
im confused..
well the company name stamped into the side of it is a hint
Old Jan 20, 2008 | 01:09 AM
TrochoidMagic's Avatar
is adjusting valve lash
huh??? i'm stumped.
cops are not retards you know? neither are they deaf.
i think they would know how a regular import sports car sound like...and of course how a ferrari and lamborghini sound like.
sure those pure sports cars will be a bit louder...but they pay a lot higher taxes on those i assume. but at which rate...it should still pull under 95 decibels under low rpm range. there's a guideline as to whats acceptable and what isn't.
i had my honda referee'd at a local college, and its a straight through cannister and passed at 93db @3k rpm.
just some FYI. mod how you want, but stay under 95db at all cost...or be far from 90db to avoid the harassment in the first place.
Old Jan 20, 2008 | 01:11 AM
oh, and to add...if you own a lamborghini, most likely you won't give a rats *** about a ticket. and neither is a cop gonna chase you. if you got that much $$$, i'm sure you already know someone to take care of it for you.
the world isn't fair...where have you been?
Old Jan 20, 2008 | 01:33 AM
faboo's Avatar
Downhill Touge FTW!!
Muffler's and resonators aren't involved in emissions...they have to do with sound level...u can change both as much as you like as long as it stays under the sound limit 95dB i think
cat's are apart of emissions...removing it is illegal...period...
its just that most states dont check for it and/or dont care...
to be legal..one needs a cat and to be under the sound limit...thats it...no confusion
SupraG
Sep 21, 2015 12:09 AM
RA32425
10
Sep 8, 2015 08:53 AM
badinfluence
Aug 31, 2015 11:51 AM
dancingdan42
Aug 19, 2015 09:29 AM
yapakanichi
16
Jul 28, 2015 03:44 PM
