Buzzing noise from engine bay @ certain RPM
Old Apr 4, 2007 | 07:06 PM
Mobile's Avatar
Not sure if this is normal or not - so I thought I would ask.
My '07 8 has about 2000 km on it. I noticed this sound right after break-in was completed and I started reving the motor, and pushing the car a bit.
I hear a light metalic buzzing noise coming from the engine bay. It sounds like there is something vibrating. One of those noises that if you put your hand on the vibrating object, it would stop.
This noise can't be reproduced by reving the engine in neutral, or slowly bringing the car up to speed - it requires load on the car for it to happen, as if it may be suspension related.
Under medium to hard acceleration, the noise starts at 6K, lasts for maybe 500rpm, then goes away. It then restarts around 7500/8K and lasts through to redline.
Sounds to me like there is just something in there that needs to be tightened up - but I thought I would see if anyone experienced a similar noise that ended up being related to the engine (which is my concern).
Old Apr 4, 2007 | 08:27 PM
Groundrush's Avatar
I have something that sounds a lot like this with mine, which is an 05 with 12k miles. Oddly, I get the same kind of rattling, during acceleration, only under load, and ONLY when the car is cold. Not reproducable with the car in neutral. Only thing is, my car does it at lower RPMs, not higher like yours. Drivin' me nuts...
Old Apr 4, 2007 | 08:38 PM
Mobile's Avatar
I don't rev my car when it's cold - but temp does not seem to be a factor. Does your noise seem to come from deep within the engine bay?
Old Apr 4, 2007 | 10:35 PM
Rhythmic's Avatar
Laid back in the pocket
I've got something like this. Mine is at high rpm and usually when its cold outside. I think this could be the TSB for a rattle under the cowl. Check to see if this TSB applies to your car.
Old Apr 5, 2007 | 08:01 AM
Rootski's Avatar
DGAF
Mine did this.. it turned out to be a loose heat shield on my aftermarket cat. If you have any aftermarket parts, check them.
Old Apr 5, 2007 | 08:17 AM
eviltwinkie's Avatar
I started hearing a rattle after replacing the cat with a midpipe...starts at 4k...goes away...comes back at 7-8k...
Very annoying...it sounded like something metallic vibrating against something else...the only thing I am thinking is that its perhaps the factory cat-back...but since it does not really happen when in neutral its hard to pinpoint driving while the windows are down...
Old Apr 5, 2007 | 09:35 AM
Stavesacre21's Avatar
1.21 Jiggawatts
I'd say reguardles sof aftermarket or not, this is a possibility. It is likely something that wasn't quite tightened down initially. I've had problems with those heat shields over the cat in numerous cars. It can be a HUGE pita.
and it's an 07 you say? Heck...drop that sucker off at the dealer. Their problem then...not yours.
Old Apr 5, 2007 | 11:09 PM
Look for something loose under da hood.
Old Apr 6, 2007 | 01:15 AM
Raptor2k's Avatar
Club Marbles Member
Exactly what I've had for a couple years. Welcome to the marbles club!
It's the intake manifold's opening of fuel valves...3rd injectors come on around 7300. It ruins the sound of hitting redline a bit, but my new MS exhaust seems to have cancelled it out enough for me to stop caring.
Search, it's normal, and dealerships aren't going to fix it.
Old May 12, 2007 | 05:37 PM
PRL 84U's Avatar
Learning to drive
Reviving this thread (from a search), I've been experiencing the same problem recently, seems to be around 3000-4000 rpm, definite metal rattling, for those who have had this problem, was it the heat shield? Going to take it in soon to have it checked out. Thanks guys!
Old May 12, 2007 | 06:01 PM
NoTears316's Avatar
Shock and Awe
Check your engine mounts. A cracked one will vibrate.
Old May 12, 2007 | 08:12 PM
Mobile's Avatar
It's going into the dealership next week to take a look. They seem to think it is the heat shield. This is not a "marble" sound.
Old May 13, 2007 | 12:47 AM
1.21 Jiggawatts
If you're hearing the rattle with a sunroof open, be sure to confirm that it's actually the ENGINE rattling and not the sunroof. 04/05's have been synonymous with the rattling sunroof, which was even finally offered a TSB.
Just a thought.
Old May 13, 2007 | 01:13 AM
Phantom Menace's Avatar
II SOCIETY
You've got marbles! Search...there is a fix!
BigMikeATL
May 26, 2016 12:31 AM
uZu
Dec 30, 2015 12:35 PM
rx8inator
Sep 1, 2015 07:18 PM
rx8inator
Aug 14, 2015 10:53 PM
iSki123
Jul 27, 2015 12:41 PM
