Front Turn Signal Bulb Replacement
Old Mar 27, 2007 | 02:52 PM
RICHARDS108's Avatar
Ok now im sure this has been asked b4 and I have done a couple quick searches to see if there were any threads on the matter but I can seem to find any. I bought some new from turn signal bulbs I don’t know how to install them I just was wondering if anyone could help me out with some info
Thanks everyone
RICHARDS108
Old Mar 27, 2007 | 05:03 PM
ac3mastuh's Avatar
Got Ings?
Easiest way if you've never done it before would be to lift the front of the car and take the wheel off. Then remove the front liner and the bulb should be there. Just turn it 1/4 turn to the left and replace.
Old Mar 28, 2007 | 04:50 PM
sweet that sounds easy enough thanks for the info
RICHARDS108
Old Mar 28, 2007 | 04:52 PM
did you get Stealth Bulbs?
Old Oct 4, 2008 | 06:19 PM
brsflorida's Avatar
Looking for way to change front Turn Bulbs to Chrome -- I Have Bulbs -- Is this the ONLY way to get to those bulbs?
Seems like a lot of work to get to a bulb?
Old Oct 4, 2008 | 06:29 PM
laythor's Avatar
I zoom therefore I am.
easiest way is to simply reach in and turn the post holding the bulb in place.
the drivers side is very easy to get to, the passenger side requires you to take off the ecu cover.
Old Oct 4, 2008 | 09:51 PM
Blazed's Avatar
I have done this before and i did not need to remove the wheel. Simply turn the steering wheel all the way right or left, depending on which side you are working on. That gives enough room to remove the front liner and change the bulbs.
Old Oct 4, 2008 | 10:25 PM
brsflorida's Avatar
Thanks I have a 2007 I Tryed from top -- removed fuse box cover -- no way to reach from there -- didn't bother on pass side because no way in on drivers -- but looks like turning wheel will do it -- Since my Clear corners are coming next week I'll try the wheel thing when I do thoose -- Thanks to both of you for the help
Solidtrance
22
Sep 4, 2015 12:47 PM
CARBONRX-8
Aug 23, 2015 09:52 PM
MarkX
Jul 31, 2015 07:50 AM
dbarber
Jul 25, 2015 01:34 PM
