Interior L.E.D lighting
Old Mar 5, 2007 | 02:32 AM
taylorscock's Avatar
taylorscock
andone here have any experience wit LED interior ligting that can offer some suggestions ?
I tnk it looks pretty cool, but would want something I could control myself. Cut on/off when I want to.
Old Mar 5, 2007 | 02:44 AM
paulmasoner's Avatar
Asshole for hire
well first you can start with LED bulbs for the OEM interior lights... many places to find the, http://autolumination.com/ makes some very nice ones. i used the 194 matrix bulbs, forget which one for the dome...
as far as adding your own lights.. one option would be make your own tube lighting. just a string of LEDs in a plastic conduit. you coul wire multi color this way if you wished. i would always fuse everything, so you could use one of the add-a-fuse things for it, and a $5 12V DC toggle from radio shack to turn on/off for just one color, you could get more creative if you did multiple colors. i beleive there are control modules made for powering/switching multiple color lighting(typically for underbody lights) that you could use, some even can tie into your music.
Old Mar 5, 2007 | 02:47 AM
PoLaK's Avatar
Son what is your Alibi?
autoillumination is crap don't use em they've gone out in my position and sidemarker lights now 3 times.
I switched to v-leds a while ago and haven't had an issue since and these highpower ones are 10x as bright.
http://frickinbrite.com/catalog/inde...cPath=81_83_97
Hes out of stock of white but they will be back in a bout 1.5 weeks.
Old Mar 5, 2007 | 03:04 AM
Asshole for hire
thanks for the heads up polak, when ever these blue ones die, or i get bored with them, i'll check there for some new whites, and also for exterior lights
Old Mar 5, 2007 | 10:47 AM
djkrazy's Avatar
Cutting the Road & Wax
I am a total newbie into putting interier lights in a car ....... i wantto put in LED or neon lights inside in the driver well ..... ummmmmm to be in detail ...... what do to you do
i want to do just like that ... that same as JRH13NJ's rx8
Old Mar 5, 2007 | 11:02 AM
Rotary Rasp's Avatar
503wtq Boosted Bimmer
Look at this thread.
https://www.rx8club.com/showthread.php?t=118507
Old Mar 5, 2007 | 01:01 PM
taylorscock
I was thinking of just purchasing the one from AutoZone. It's like a 6" led that is a tube/stick and is bendable. Plugs into cig. lighter and you plug and unplug as you want it.
Old Mar 5, 2007 | 01:24 PM
StealthTL's Avatar
Cool Lots'o'watts.....
Got a little carried away with the LED thing, modified my overhead map lights to take a 3-Watt blue. That's a huge LED, takes a large resistor and needs a heat sink on the back to channel the heat away.
It was probably overkill, melted a little patch on my overhead console......but LOTS of light !
S
Old Mar 5, 2007 | 02:23 PM
chickenwafer's Avatar
Nope
S
Probably overkill?? LOL you had to add a heat sink! That was too funny!
djp6783
Sep 19, 2015 12:12 PM
Randolph Alvarez
Sep 14, 2015 04:25 AM
erikcamacho15
Sep 12, 2015 11:23 AM
Irvinb16
Sep 11, 2015 10:27 PM
