Can I use SAE 10-30W oil in MY RX-8
Old Feb 26, 2007 | 12:18 PM
bandalgom78's Avatar
Well, I put SAE 10-30W castrol oil in my RX-8.
Well, I just found out that need to put 5-20W.
well, You think I need to change oil right away or I can use 10-30W.
Old Feb 26, 2007 | 12:45 PM
You'll be fine.
Im too lazy to start a Engine Oil 101. so
As long as your local Temp wont drop below freezing point.
Old Feb 26, 2007 | 02:47 PM
CarAndDriver's Avatar
2005 Black RX-8 GT 6M
You'll be fine....most people use 5W-20 or 5W-30 though. It takes about 3 oil changes to completely get out previous oil so you currently have a mix of old and new.
No worries.
Old Feb 26, 2007 | 02:57 PM
rglbegl's Avatar
Baned
DO NOT START THE CAR!!!!!! YOU WILL RUIN THE CAR!!!!!!!
j/k lol
Old Feb 26, 2007 | 02:59 PM
Winning 8's Avatar
Hot Pit
it give you better protection, but less power and gas milages.
Old Feb 26, 2007 | 06:16 PM
PerformRX-8's Avatar
ROTARY-A-HOLIC
Shall i say do a search!
Old Feb 26, 2007 | 10:51 PM
astro's Avatar
5W30 is specified for AU spec models. So far, there's not too many that I know of who has had issues with their engine down here.
Old Feb 27, 2007 | 12:13 AM
Originally Posted by astro
5W30 is specified for AU spec models. So far, there's not too many that I know of who has had issues with there engine down here.
It is spec everywhere except Canada and the US.
Old Feb 27, 2007 | 12:29 AM
Cody Red's Avatar
always filling [the c]up
My friend with a half-bridge ported fd uses 10w30. Claims he's always used it, works just fine. I know this has nothing to do with a high performace rotary, but I, myself don't use that, I use 5w30.
-Cody
Old Feb 27, 2007 | 12:37 AM
thisllub's Avatar
My owner's manual has everything from 5W20 to 15W50 depending on temperature.
Old Feb 27, 2007 | 09:28 AM
CyprusRX8's Avatar
JDM Type-S 6-speed 250PS
5W30 for Europe as well.
Old Feb 27, 2007 | 09:30 AM
5w30 for the rest of the world EXCEPT USA and Canada.
USA and Canada use 5w20 cuz it gives better emission.
Old Feb 28, 2007 | 10:32 AM
otakurx's Avatar
Rotorheaded Geek
It is all I run, except in the winter I run 5-30. The 8 loves it and so does the 7.
Old Feb 28, 2007 | 10:40 AM
rotarygod's Avatar
After the engine is at operating temps, a 0W30, 5W30, 10W30, and straight 30W oil are all the same thickness. It's only at warm up that they are different and even then depending on how cold it really is it may not be that different as colder and colder would be closer to the bottom number. On an 80 dgree day it isn't the difference between 5 and 10 but actually much closer. Your engine doesn't really even know. Most RX-7 owners use 20W50 and I did for a long time until I switched to a thinner one just because people said I couldn't. Don't worry about it. As long as you have oil in the engine, you're fine.
Old Feb 28, 2007 | 11:14 AM
NoTears316's Avatar
Shock and Awe
good job
Old Feb 28, 2007 | 11:18 AM
otakurx's Avatar
Rotorheaded Geek
I have always liked thicker oils, but with temps here down in the single digits sometimes ya. But the only reason I don't run more then sae30 is for my own peace of mind with the MOP. When I premix ya tractor oil is fine (esp for those high revvs)
ouimetnick
25
Sep 14, 2023 01:44 PM
drebbrnator
Dec 27, 2018 07:02 PM
uZu
Dec 30, 2015 12:35 PM
Sifu
Aug 30, 2015 10:51 PM
vssystemluba
Jul 19, 2015 04:16 PM
