car pulls sumtimes
Old Feb 22, 2007 | 05:55 PM
prospectjtaz's Avatar
car pulls sumtimes
So ya, looked over cant really find anything, please dont flame. Just got the car, but sumtimes wen im driving, it will pull either to the left or right, its understandable sumtimes cuz of the road, but sumtimes the road could be perfect and it still does, even wen braking sumtimes. Is something wrong with the differential? A noob to the mechanics of the car, so any help would be appreciated. Also hearing a ringing sound when accerlating after switching gears, goes away when I give it more gas, normal or...?
Old Feb 22, 2007 | 06:09 PM
staticlag's Avatar
The Professor
How many miles are on the car?
Is it modified?
How many miles have you personally driven it?
Old Feb 22, 2007 | 06:10 PM
8is>enuff's Avatar
Bland
As for the pulling, look up tramlining. There's a good article on it on Tirerack.com and a bunch of info on it here.
No clue about the ringing, unless you have a 6MT and you're talking about the shift beep, which is an auditory reminder to shift gears and goes off at 8500RPM.
Old Feb 22, 2007 | 06:28 PM
its got 33 000 miles on it, drivin prolly less than a 1000. no its not the redlining beep, and its bone stock.
Old Feb 22, 2007 | 07:05 PM
staticlag's Avatar
The Professor
The ringing is the ports on the engine opening, it is normal.
The previous owner probably replaced one flat tire but left the others in worn condition. So one good tire is gripping the road but the rest need to be replaced. Look at the brand and treads of all 4 tires and see if this is the case.
Old Feb 22, 2007 | 07:35 PM
DarkBrew's Avatar
Extraordinary Engineering
Maybe you could post a bit of information about yourself and the car in your profile or in your signature... (look under user/cp)
What kind of tires are on the car? Stock wheels?
Old Feb 23, 2007 | 09:18 AM
18" brand new khumos
Old Feb 23, 2007 | 11:33 PM
BlueRenesis82's Avatar
Registered Tracker
is english your first language?
Old Feb 23, 2007 | 11:51 PM
30k miles get an alignment.
The ringing, my bet it's normal. Do some more reading hear.
Welcome to the club.
Old Mar 1, 2007 | 10:39 PM
coolme668's Avatar
do you directional tires?
that might be the problem if you do.
delicious_dallan
Jan 17, 2020 09:17 AM
BigMikeATL
May 26, 2016 12:31 AM
Obivious
Jul 29, 2015 05:57 PM
madrotor
Jul 26, 2015 12:06 PM
Bamaham
Jul 23, 2015 08:08 AM
