How many cfps of exhast does the engine put out?
Old Feb 18, 2007 | 06:05 PM
Digital_Damage's Avatar
Does any one know how many cfps does the engine put out at idle and wot?
Old Feb 18, 2007 | 08:45 PM
Brettus's Avatar
Boosted Kiwi
it would be the same as what goes in ..... right ?
there are a few threads on this - here is a readout from the maf at WOT
Old Feb 18, 2007 | 11:33 PM
NotAPreppie's Avatar
What am I doing here?
Not necessarily. Air going in is going to be much cooler (and, as predicted by Boyle's Gas Laws, much denser) than what will come out. There's also the relative densities of the gases at similar temps (air v.s. exhaust gasses).
Now, a similar mass of material should come out of the engine as what goes in (in the form of air and fuel). Which would lead me to believe that output rate would be much greater than input rate as you are turning a (relatively) dense material (gasoline) into a far less dense material (gasseous CO, CO2, H2O, N2O, SO2, etc).
Old Feb 20, 2007 | 08:51 AM
1145climber's Avatar
RX-8 Enthusiast
yeah - the gas products of the fuel combustion probably account for a big portion of the exhaust... if air in = air out, then there wouldnt be any CO2 emissions problems contribution to global warming.
i'm curious to know the answer to this question as well
Audio Concepts ATL
Sep 26, 2021 01:59 PM
vapor2
Nov 3, 2020 03:38 PM
cschoeps
Aug 6, 2015 12:44 PM
Rx8Lovin
Jul 25, 2015 08:39 PM
Belalnabi
Jul 17, 2015 07:48 PM
