weird problem in low rpms
Old Feb 14, 2007 | 01:50 PM
Chris's Avatar
Turbo Member
just wanted to know if anyone has an idea of what could be wrong. At idle the car is very rough and if the clutch is released all the way then there is a bad belt sound (like a light skreech)... now for the real problem when starting out the car sounds deeper/throaty and struggles from 0-3800 rpms. when the engine is cold you can feel a real spike at 3800rpms, you can feel the car come back to normal power. Any ideas guys? no cels and the oil is ok... its getting changed tomorrow but i really dont think this is an oil problem
Old Feb 14, 2007 | 11:10 PM
Your not supposed to drive the car when cold. The ECU will retard timing and make you slow down.
Old Feb 15, 2007 | 06:52 AM
Mazda-Rati's Avatar
the WANKEL made me do it
Aren't a second set of intake ports supposed to open up around 3800rpm? maybe the first ones aren't opening up.
Old Feb 15, 2007 | 07:16 AM
LostAngel's Avatar
Yes, around 3800 the intake ports open up (causing a slight drip in power then going back up). This also happens at around 7400rpms or so.
Also, I sometimes get the clutch squeal when applying the clutch...usually if im just about stopped and I press the clutch in.
Old Feb 15, 2007 | 07:32 AM
invasion08's Avatar
You can drive the car when it is cold you just cant turn it off becasue it may flood
Old Feb 15, 2007 | 07:48 AM
Mazda-Rati's Avatar
I found this from a while ago explaining the S-DAIS system in the 8
https://www.rx8club.com/showthread.p...ghlight=s-dais
Looking at the chart zoom44 put up. Maybe it's the #1 injectors? not doing their job and at 3750rpms is when the #2 pri. and sec. start
uZu
Dec 30, 2015 12:35 PM
Solmors
Aug 21, 2015 10:11 PM
MarkX
Jul 31, 2015 07:50 AM
Belalnabi
Jul 17, 2015 07:48 PM
kaboshe
Jul 17, 2015 03:14 PM
