does your left headlight aim lower than the right?
Old Feb 9, 2007 | 05:21 PM
kaoman's Avatar
Does your left headlight aim lower than the right? I know projectors have a beam pattern ____/------- but after getting my car back from the bodyshop, my left headlight points significantly lower than the right, so much so that I can see two distinct beam patterns even less than a few feet away from my garage door. When I pull up behind a car, only the right headlamp hits the body of the car.
It's hard for me to judge because I was driving for about a month with my left headlight pointed literally at the ground from a parking collision. I don't remember what my halogen oem lights looked like before then.
I'll take pictures later tonight when its darker..
Old Feb 9, 2007 | 05:25 PM
User24's Avatar
I've learned from reading RX8club that it is supposed to be like that.
Old Feb 9, 2007 | 05:27 PM
dillsrotary's Avatar
jersey fresh
its normal, its called the Z pattern, driver side is lower so you don't blind on coming traffic
Old Feb 9, 2007 | 05:46 PM
kaoman's Avatar
this shot is from about 3 feet away..
about 8 ft away..
16 ft
zoomed in
just driving around
I appreciate your guys' opinion.
Old Feb 9, 2007 | 05:55 PM
mysql101's Avatar
from this picture, it looks like your lights are off more than the usual amount...
Old Feb 9, 2007 | 05:57 PM
User24's Avatar
I can try some photos tonight, but mine do not quite look like yours. You have a staircase Z pattern, mine is more like a double V pattern.
In the same vein, I have been in front of a trucks that had real powerful lamps. I get quite angry and think to myself, "That's why HID are not meant for self-install..." and I turn my outside mirrors down.
Old Feb 9, 2007 | 06:11 PM
staticlag's Avatar
The Professor
Your headlights are really misaimed, take it into the dealership.
Old Feb 9, 2007 | 06:25 PM
kaoman's Avatar
im unsure if the dealer will be able to do anything--it's the body shop that disassembled and reassembled the headlight/bumper/left fender.
I know the left lamp should be lower than the right lamp marginally, but im in a situation where i think the difference is too much. I dont know if my judgement is off because of how long ive been driving with collision damage so thats why I'm asking you guys. I dont wanna walk into the body shop talking like an ***.
abbid I just drew circles around the center of the bulb patterns in the photo you copied. My left lamp hits the bottom of the driveway, my right the garage doors. This is normal?
Old Feb 9, 2007 | 06:33 PM
BigAAA's Avatar
I just bought mine, and they do that, maybe not as bad, but it is definately there.
Old Feb 9, 2007 | 07:12 PM
Easy_E1's Avatar
They look way off. I would have them adjust the left one up. I have mine so the top of both beams are even. This still has the drop on the left side and no one has flashed me for having them aimed incorrectly.
Old Feb 9, 2007 | 07:23 PM
mysql101's Avatar
in case you're unaware, the lights are adjusted by a regular screwdriver. Just push the tip in, and twist. No need to remove the bumper or anything. Just pop the hood and go.
Old Feb 9, 2007 | 07:31 PM
jersey fresh
do your lights hang low
do they wobble, do they flow
can you tie them in a knot
can you tie them in a bow
Old Feb 9, 2007 | 08:53 PM
kaoman's Avatar
I adjusted the lamp myself and now it makes a proper staircase. I also had someone drive towards me and he said the level is fine. Thanks for everyone's help!
Next order of business.. washing and waxing in sub-20 degree weather...
Old Feb 9, 2007 | 10:46 PM
d j's Avatar
d j
hukbong himpapawid
get some deicing fluid, mix it with water and dump it on yor car. presto! winter proof!!!
Old Feb 10, 2007 | 07:02 AM
Mazda-Rati's Avatar
the WANKEL made me do it
Only when its warm out. When it's cold I can't really tell
Old Feb 10, 2007 | 09:37 PM
User24's Avatar
Do you still have 3 breaks at 16 feet? At around 15 feet I have 2 breaks:
Old Jul 4, 2007 | 07:07 PM
aydiomio's Avatar
hello,
question, HOW DID YOU GOT TO ADJUST THEM??????
Jst4fun
Apr 17, 2021 07:43 AM
Jst4fun
Mar 5, 2021 07:16 PM
Digitz0070
Sep 25, 2015 10:58 PM
yankeepicker
Sep 11, 2015 05:42 PM
Tsurugi
Sep 7, 2015 08:27 PM
