hot center console
Old Feb 8, 2007 | 02:20 AM
texter's Avatar
hot center console
Hi all,
got my 6AT last week. Been reading on past thread on the center console (next to my left leg while driving), cup holder being warmed due to the transmission axle. I do not know wat it means until i get the car.
What are some of the solutions that some of you do to reduce the heat?
Old Feb 8, 2007 | 02:32 AM
wen pin's Avatar
Originally Posted by texter
Hi all,
normal lah. live with it. or turn the a/c cooler lor..........
Old Feb 8, 2007 | 08:09 AM
cuscorex's Avatar
爆 走 RE风 林 火 山
a free-flow xhos sys will help
Old Feb 8, 2007 | 08:18 AM
RX-EGG's Avatar
RX7LEVINVR4SILVIACRVRX8
Hi all,
is very normal...RWD sportscar is all like tat, S13 and Silvia also the same.
sandman369's Avatar
Hi all,
you would get used to it. some folks here enhanced insulation under the cup holders (centre console can easily be removed). you can try searching to see what these guys have done.
Old Feb 8, 2007 | 09:49 AM
texter's Avatar
How will a free flow exos system help?
Yes, heard about the insulation from other threads. Which workshop does that?
Old Feb 8, 2007 | 10:17 AM
Rei's Avatar
Rei
White Rotary
I think living wif it is a gd choice...its mighty useful when ur transporting a warm
cup of kopi...heehee...
Old Feb 8, 2007 | 10:20 AM
Wilson's Avatar
Peeping over the fence
It is not that hot. It won't burn you and you can't cook in it.
Old Feb 8, 2007 | 07:54 PM
lennon's Avatar
Cat stores heat, so a free flow eksos will get rid of the heat.......
Old Feb 8, 2007 | 09:46 PM
dr11855i's Avatar
wear thick pants and underwear so that the heat wont get to you!
Old Feb 8, 2007 | 10:34 PM
effie's Avatar
Nightmares be gone...!!!
Originally Posted by lennon
Cat stores heat...............
Yups......a CAT in "HEAT" is certainly a problem...... We wouldn't want a lot of humping going on under our 8's rite
Old Feb 8, 2007 | 11:23 PM
Phantom Menace's Avatar
II SOCIETY
The "foot-warmer" bump? Why is that next to your left leg? Are you guys RHD?
Old Feb 9, 2007 | 12:11 AM
Silver_Z's Avatar
Yep. Thanx to the brits, we are on the wrong side of the road.
Old Feb 9, 2007 | 12:40 AM
II SOCIETY
I've been meaning to ask you guys...to go into 1st gear, do you push the stick up and to the left? And reverse, down and all the way to the right?
Old Feb 9, 2007 | 12:57 AM
Silver_Z's Avatar
Mine just have to shift down 1 notch to reverse and another 2 notch to drive.
Yea. Left top for 1st gear and right bottom for reverse(5MT), not sure bout the 6MT.
Old Feb 9, 2007 | 01:31 AM
texter's Avatar
Guess i have to get used to it.
Old Feb 9, 2007 | 02:14 AM
lennon's Avatar
You can install an aftermarket firewall.... Only cost few hundreds...
Old Feb 9, 2007 | 02:21 AM
texter's Avatar
Whats a aftermarket firewall? Something like the insulation that is discussed in the other thread? Where can i do this?
foo77's Avatar
4th batch : Apr 03'
here's the solution
http://www.hi-impact.org/ryang/modif...8_console.html
Old Feb 9, 2007 | 02:50 AM
mkl22's Avatar
pedals and gears are the same for LHD and RHD cars, the only difference for some cars is the indicator stalk Left for LHD and right for RHD, but some manufacturers are lazy and dun bother to switch Left to right.
ShellDude
Oct 1, 2015 09:55 PM
archon
Oct 1, 2015 06:08 AM
XianUnix
Sep 29, 2015 03:48 PM
FubarI33t
Sep 28, 2015 08:45 PM
