crazy car
Old Feb 4, 2007 | 08:23 AM
cowboyup75146's Avatar
crazy car
Last night my wife came in and said her car just shut off by it self [05 black RX8 29000] and the dsc light was blinking , then stayed on . I rode with her and it seemed like if you useed the window switch to lower the window it was a drain on the battery/ alt . We drove around for a while and then dsc lihght just stayed lit not blinking. I told her park it and we would come back in 5 min. Started the car and everything is ok????????
ANY THOUGHTS
Old Feb 4, 2007 | 09:01 AM
Spin9k's Avatar
Momentum Keeps Me Going
shut off when? at idle ... at interstate cruise speed... at a stop light?
generally the dsc light will be on when starting after a battery disconnect .. and off again if you shut off and turn on the 2nd time.
Why? because the dsc loses calibration, and the manual says to re-calibrate the dsc function, you need to turn the steering wheel all the way to the right, then left after a battery disconnect.
so perhaps check the bolts are tight on the battery posts , no corrosian, get a battery capacity check.
Skyl3r
Dec 2, 2019 04:51 PM
iSki123
Jul 27, 2015 12:41 PM
Peanutbuttertruffle
Jul 24, 2015 07:49 AM
Bamaham
Jul 23, 2015 08:08 AM
shambo
Jul 18, 2015 02:07 PM
