Any way to get these rims to fit??? :(
Old Jan 28, 2007 | 09:38 PM
rx8guy86's Avatar
Drive Like you stole it
I ordered a set of Axis Mod rims that were used, with new tires. Got them in and they dont fit. Just barely off. Here are the rim details
Rim Width: 8.5J
Tire Width: 245
Rim Diameter (inches): 19
Aspect Ratio: 40
Offset: 35
Load Index:
Number of Bolts: 5
Speed Index: ZR: over 240 km/h
Bolt Pattern: 5 x 5.12 or 5 x 130
Any way to get these to work?? I hate to have to go thru all the hassle of reselling these. Especially for the great deal I got on them... Thanks in advance!
Old Jan 28, 2007 | 09:48 PM
Silverarrow's Avatar
OldeSpeede, Inc.
No easy way to get them to fit, the bolt pattern is wrong. you need 5x114.3. I think some places sell wheel adapters(Eibach and H&R come to mind) if you really need to use those wheels.
Old Jan 28, 2007 | 09:51 PM
LionZoo's Avatar
road warrior
Your bolt pattern is wrong, your offset might be too low, your wheel and tire combination is an inch larger than stock. To fix that, you'll need to roll your fender or get new ones and get a new hub. Unless you're willing to do that (and I highly recommend against it) you're going to have to sell or trade them. For starters, you want a wheel that has a 5 x 4.5" (114.3 mm) bolt pattern. Also, if you want 245 width tires on 19s, you probably want to run 245/35-19s, not 40 aspect ratios.
Old Jan 28, 2007 | 09:56 PM
no is the answer..
Old Jan 29, 2007 | 10:25 AM
rx8guy86's Avatar
Ok, I appreciate everyone's responses. Thanks!!!
Old Feb 2, 2007 | 12:19 PM
rx8guy86's Avatar
Well, I found that these Axis mod rims have steel spacers in them to make them 112. I should be able to pop those out to make them fit. These rims are only made in 114.
Old Feb 3, 2007 | 08:15 PM
c41250n's Avatar
yes...you need 5X114, you can either buy a hub to change the lug pattern to 5X112 or 5X130.
but i think it will be cheaper if you just buy a new set of wheels and sell the one you can now!
Old Feb 4, 2007 | 06:24 AM
rx8guy86's Avatar
I got them to fit Just popped out the spacers.
click to make larger
Old Feb 5, 2007 | 02:59 AM
c41250n's Avatar
looking good!
so you used the spacer? how much did it cost you?
Old Feb 5, 2007 | 08:31 AM
rx8guy86's Avatar
Originally Posted by c41250n
looking good!
No, the previous owner uses Lug spacers, which made the bolt pattern 5x112. After looking on the site and talking with Axis, I found out that they didnt make these rims in that size. I emailed Axis about the issue. The rep saw the pic of the inside of the rim and informed me about the spacers. I knocked them out. That made the wheel size 5x114 which fit the car. Understand? Thanks!
Old Feb 5, 2007 | 10:28 AM
I hope you placed a bet on the lottery this week ...
Old Feb 5, 2007 | 11:21 AM
Tanaka826's Avatar
hahaha lucky man.
Old Feb 6, 2007 | 04:02 AM
c41250n's Avatar
thatz a good news...saved you a lot of money!
Old Feb 6, 2007 | 11:05 PM
gasoholic's Avatar
Looking good, is your car lowered?
Old Feb 14, 2007 | 09:20 PM
rx8guy86's Avatar
No, its not lowered
TotalAutoPerformance
Vendor Classifieds
12
Oct 17, 2018 09:00 AM
Rx8 VA Guy
Jun 4, 2016 12:42 AM
hufflepuff
May 30, 2016 10:45 AM
Quiggs321
Sep 30, 2015 05:34 PM
GK1707
Sep 27, 2015 07:33 PM
