Mazda Special Program MSP13
Old Jan 27, 2007 | 11:10 AM
Another bulletin on its way. Its been a long time it seems since a new one
So MSP13 deals with a sealing issue of the gas cap on 2006/07 CX-7s ,MX-5s and RX-8s built between certain dates. The issue cause a Evap system CEL ofn effected vehicles.
TO: Mazda Dealership Service Managers
DATE: January 2007
SUBJECT: Mazda Service Program-MSP13
Mazda Motor Corporation has decided to conduct a Mazda Service Program (MSP) on 2007 CX-7 vehicles built from February 14, 2006 through August 1, 2006, 2006-2007 MX-5 vehicles built from January 6, 2006 through August 2, 2006, and 2006-2007 RX-8 vehicles built from January 7, 2006 through August 2, 2006. It is possible that a malfunction indicator light may illuminate with DTC P0455 (EVAP system leak detected-large leak) stored in memory, due to poor sealing between the fuel filler pipe and fuel filler cap.
Please perform MSP13 for all applicable vehicles in dealer inventory and when owners bring their vehicles in for regularly scheduled maintenance or other service work. Please explain to the customer that a new fuel-cap was installed in their vehicles free of charge.
Old Jan 27, 2007 | 11:12 AM
TSB
TSB: 01-001/07
2007 CX-7, 2006-2007 MX-5, 2006-2007 RX-8 - MAZDA SPECIAL PROGRAM (MSP13) - MIL ILLUMINATION WITH DTC P0455
APPLICABLE MODEL(S)/VINS
2007 CX-7 vehicles with VIN JM3ER29**70100057 - JM3ER29**70128616 (built from February 14, 2006 through August 1, 2006)
2006-2007 MX-5 vehicles with VIN JM1NC**F*60111723 - JM1NC**F*70125568 (built from January 6, 2006 through August 2, 2006)
2006-2007 RX-8 vehicles with VIN JM1FE173*60200012 - JM1FE173*70208462 (built from January 7, 2006 through August 2, 2006)
DESCRIPTION
It is possible that a malfunction indicator light may illuminate with DTC P0455 (EVAP System Leak Detected-Large Leak) stored in memory, due to poor sealing between the fuel filler pipe and fuel filler cap.
NOTE:
UNDER THE MAZDA SERVICE PROGRAM (MSP13), ALL CURRENT DEALER INVENTORY AND RETAILED VEHICLES FOUND TO BE WITHIN THE ABOVE PRODUCTION AND VIN RANGES MUST BE INSPECTED AND REPAIRED ACCORDING TO THE INSTRUCTIONS CONTAINED IN THIS SERVICE BULLETIN. THIS INCLUDES CUSTOMERS WHO HAVE BROUGHT THEIR VEHICLE IN FOR NORMAL SCHEDULED MAINTENANCE AND/OR OTHER SERVICE WORK THAT MAY NOT BE RELATED TO THE CONCERNS OUTLINED IN THIS BULLETIN.
BEFORE PERFORMING ANY REPAIR, VALIDATE THAT THE VEHICLE IS APPLICABLE TO THIS PROGRAM BY PERFORMING AN "eMDCS" WARRANTY VEHICLE INQUIRY "AND VERIFYING THE VEHICLE DISPLAYS CAMPAIGN "MSP13" AND ITS CAMPAIGN STATUS DISPLAYS "OPEN". SEE "VEHICLE INSPECTION PROCEDURE" BELOW.
DEALER INVENTORY:
Repair all applicable vehicles currently in dealer inventory according to the procedures contained in this service bulletin.
RETAIL VEHICLES:
When an applicable retail vehicle is brought into the dealer for any type of repair or scheduled maintenance, perform an eMDCS Warranty Vehicle Inquiry and check the status of MSP13. If status of MSP13 is "OPEN", repair the vehicle according to the procedures contained in this service bulletin.
1. Verify the vehicle is within the following production and VIN ranges:
o
VIN Range: JM3ER29**70100057 - JM3ER29**70128616
o
VIN Range: JM1NC**F*60111723 - JM1NC**F*70125568
o
VIN Range: JM1FE173*60200012 - JM1FE173*70208462
If the vehicle is within the above Production and VIN ranges, proceed to Step 2.
If the vehicle is not within the above Production and VIN ranges, return the vehicle to the customer or inventory.
2. Perform a Warranty Vehicle Inquiry using your eMDCS System and inspect the vehicle for a Campaign Label MSP13 attached to the vehicle’s bulkhead. Refer to eMDCS System - Warranty Vehicle Inquiry Results table below.
NOTE: Verify the campaign number as the vehicle may have multiple labels.
If eMDCS displays:
Campaign Label is:
Action Required:
"Campaign: MSP13 Open"
Present
Contact the Mazda Corporate Dealer Assistance Group at (877) 727-6626 to update vehicle history
Not present
Proceed to "REPAIR PROCEDURE"
"Campaign: MSP13 Closed"
Present
Return vehicle to inventory or customer
Not present
Complete a label and apply it to vehicle’s bulkhead
"Campaign: MSP13 Open" or "Closed" is not displayed
Does not apply
Campaign does not apply to this vehicle. Return the vehicle to inventory or customer
REPAIR PROCEDURE
1. Verify customer concern.
2. Replace fuel filler cap with a modified one.
3. Fill out a blue "Campaign Label" (9999-95-065A-05) with the Campaign No: "MSP13", your dealer code, today’s date, and affix it to the vehicle’s bulkhead.
4. Verify repair.
5. Return the vehicle to the customer.
PART(S) INFORMATION
Part Number
Description
Qty.
Notes
FEY2-42-250
Fuel Filler Cap
WARRANTY INFORMATION
NOTE:
This warranty information applies only to verified customer complaints on vehicles eligible for warranty repair. Refer to the Warranty Wizard for warranty term information.
Repairs performed outside the New Vehicle Limited Warranty will require DCSM or DSA authorization.
Additional diagnostic time cannot be claimed for this repair.
Warranty Type
A
Symptom Code
99
Damage Code
99
Process Number
A0685A
Part Number Main Cause
FEY2-42-250
Quantity
Operation Number / Labor Hours
XXB493RX / 0.2 Hrs.
Old Jan 27, 2007 | 02:39 PM
Old Rotor's Avatar
Exclamation
Thanks "ZOOM44" we can really count on you....do you ever log off??? I'd be scared to shut it down it might never come up again......LOL.
Old Jan 28, 2007 | 12:50 PM
ken-x8's Avatar
Thanks, Zoom. I got that code a month or so ago. Thanks to a forum search, I learned what it was, and have been paying more attention to my gas cap. (Read and cleared the code with my Harrison CANscan.)
Next month when I bring my 8 in for an oil change I'll bring a copy of this along.
And see if the dealer takes my word for it that I got the code.
Ken
Old Jan 28, 2007 | 03:40 PM
dillsrotary's Avatar
jersey fresh
thanks alot zoom
czr
Sep 13, 2015 11:37 AM
Sakebomb Garage
Vendor Classifieds
Sep 6, 2015 03:30 PM
Sakebomb Garage
Sakebomb Garage
Sep 6, 2015 03:29 PM
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
