Stainless Steel Clutch Line
Old Jan 17, 2007 | 12:33 AM
andylam85's Avatar
Does anyone have upgraded clutchlines? I've done a search and did not find much info. I am doing a clutch/flywheel install soon and wondering if I should upgrade the clutch line to stainless steel at the same time.
Any help would be greatly appreciated. Thanks
Old Jan 17, 2007 | 06:09 AM
Mazda-Rati's Avatar
the WANKEL made me do it
https://www.rx8club.com/showthread.p...ht=clutch+line
Corksport has an SS clutch line for $25
DYI here ---> https://www.rx8club.com/showthread.p...ht=clutch+line
Old Jan 17, 2007 | 09:24 AM
woodysjh's Avatar
I already searched!!!!!!!
I installed the Corksport clutch line myself. Easy to do and it does seem to make the shifting easier. I used the DIY.
Old Jan 17, 2007 | 09:39 AM
Hightshoe's Avatar
'05 Titanium 6sp
You should definitely upgrade to the ss clutchlines if you're installing a new clutch. You wouldn't even have to track your car to notice the difference. In heavy stop and go traffic you'd be able to tell.
Old Jan 18, 2007 | 11:54 AM
BlueRenesis82's Avatar
Registered Tracker
I have the Rotary Performance one, certainly seemed to help with the 1-2 shift.
Old Jan 19, 2007 | 02:46 PM
msrecant's Avatar
Hubble has been saved!
From what I have read if you routinely drive the pedal to the floor stop you will probably not notice a difference when shifting with a SS clutchline in street applications. If, like me, you don't always get the pedal quite all the way to the floor you will probably feel a difference.
I opted for a seat adjustment rather than installing the SS clutchlines.
ÜberJumper
Canada Forum
21
Feb 20, 2025 11:57 AM
9krpmrx8
Oct 13, 2015 01:36 PM
tgaffner
Sep 7, 2015 08:49 PM
Kim Jong Illest
Sep 4, 2015 04:27 PM
