2008 Tribute Hybrid Electric Vehicle 'HEV' Pics
Old Jan 7, 2007 | 11:55 PM
ASH8's Avatar
Super Moderator
A TRUE BREATH OF FRESH AIR:
THE 2008 MAZDA TRIBUTE HYBRID
Detroit, 7th January 2007.
Showing its commitment to improving the world’s air quality, Mazda North American Operations (MNAO) will unveil the all-new 2008 Mazda Tribute Hybrid-Electric Vehicle (HEV) at the 2007 North American International Auto Show. With a hydrogen-powered version of the RX-8 and a hydrogen-powered hybrid version of the MAZDA5 undergoing extensive testing in Japan, the Tribute HEV is the latest environmentally friendly vehicle to join the Mazda line up. Tribute HEV will debut in mid-2007 (in the North American market only), as a 2008 model-year vehicle. Mazda will provide more details – exact timing, pricing, distribution, sales volumes, etc. – closer to the launch date. “With virtually all new Mazda vehicles sold in the U.S. earning either Low Emission Vehicle (LEV) or Ultra Low Emission Vehicle (ULEV) status, protecting the global environment is a long-standing concern of ours,” said Robert Davis, senior vice president, Quality, Research and Development, MNAO. “The Tribute HEV is the next step towards strengthening Mazda’s environmental efforts.” A “full” hybrid, the Tribute HEV can run on 100 percent electric power up to approximately 25 mph (40 km/h), maximizing in-city fuel economy and making it one of the least-polluting vehicles sold. Still, the Tribute HEV stays true to the Zoom-Zoom Mazda owners have come to expect by delivering the performance required by SUV owners. The Tribute HEV provides plenty of power yet meets California’s strict Advanced Technology Partial Zero Emissions Vehicle (AT-PZEV) requirements by achieving Super Ultra Low Emissions Vehicle II (SULEVII) standards, plus zero evaporative emissions standards – the strictest emission regulations a petrol-fuelled vehicle can meet.
Tribute HEV technology, at a glance: • A special 2.3-liter four-cylinder petrol engine features Atkinson-cycle combustion for improved efficiency and produces 133 PS at 6,000 rpm. • A 70-kWatt (equivalent to 94 PS) electric traction motor provides an added boost to the drive wheels when maximum acceleration is desired. • A generator-motor recharges the batteries, starts the engine and helps regulate how the two propulsion channels blend together in the transaxle. • A special electronically controlled, continuously variable transmission (eCVT) harnesses internal combustion and electric power sources to drive the vehicle. • A 330-volt nickel-metal-hydride battery pack located and sealed at the rear load floor stores electrical energy. • An electronic vehicle system controller manages charging, drive assist and engine-starting functions. This device shuts the engine down during coasting and at stoplights to save fuel. It also converts the traction motor into a generator during braking to help recharge the batteries. The Tribute HEV offers superior environmental performance with its MZR 2.3-liter petrol engine, which has been modified to run on the Atkinson combustion cycle for superior fuel efficiency. The Atkinson cycle modifies the timing of the closing of the valves, enabling the engine to realize more power with cleaner emissions. At low speeds or in low-load situations, drive is provided by a permanent magnet AC synchronous electric motor, producing 70 kW @ 5,000 rpm and 330 V maximum voltage.
When additional power is required, the Tribute HEV's 2.3-liter DOHC 16-valve Atkinson cycle four-cylinder engine seamlessly engages, contributing 133 PS at 6,000 rpm and 124 lb.-ft of torque at 4,250 rpm. As a result, the Tribute HEV pushes out a combined 155 PS with 0-100 km/h times comparable to a 200 PS V-6 engine, while improving city-driving fuel economy by nearly 75 percent. The Tribute HEV is equipped with a smooth-shifting, electronically controlled continuously variable transmission (CVT) that realizes seamless, highly efficient adjustment of the gear ratio under electronic control. Once the vehicle reaches speeds above 25 mph (40 km/h), or vehicle load exceeds a certain threshold (such a fully-laden vehicle or a “jack-rabbit” start), the motor supplements the petrol engine, providing extra torque as needed. During deceleration, it charges the battery by working as a generator. The generator-motor also provides power boosts during heavy load situations, helping Tribute HEV accelerate briskly to speed. In addition to fuel-free operation, electric motors deliver maximum torque at low rpm, so they are an ideal complement to petrol engines that generate peak power at higher rpm. The transition through four modes – all-electric, petrol-electric, petrol-only and charging the battery pack – is seamless, and the only clue to the mode in which the vehicle is operating is the “charge/assist” gauge on the dashboard. An electronic vehicle system-controller manages charging, drive-assist and engine-starting functions. This device shuts the engine down during coasting and at stoplights to save fuel. It also enables the traction motor to convert to a generator to provide engine-braking and recharge the batteries. Equipped with standard front-wheel-drive or optional electronic four-wheel-drive, Tribute HEV is offered in two trim levels, Touring and Grand Touring. Mirroring design cues shared by the Mazda Tribute petrol-only model, Tribute HEV offers a bold, rugged exterior set off by 16-inch alloy wheels and new front and rear fascias, hood, liftgate, body-side moulding, power side view mirrors, headlamps, tail lamps and standard fog lights – features that can all be found on the redesigned conventional 2008 Tribute as well.
Like all good SUVs, the Tribute HEV has a high seating position for the driver, great visibility, good ground clearance, a tall roof and large cargo area. The elevated seating position and superb visibility mean drivers get a better view of the road when weather conditions are bad, such as heavy driving rain. The vehicle seats five adults in comfort. Storage compartments in both front doors provide easily accessible storage options. In addition, a centre console storage compartment with removable bins offers enough space to store a laptop. There is 29.2 cubic feet (827 litres) of carrying space behind the rear seat when it’s up, and 66 cubic feet (1,869 litres) when the seatback is reclined. The rear seat is asymmetrically split 60:40, which improves carrying versatility. For extra practicality, the tailgate features a rear window that lifts separately, ideal for loading less heavy objects. Safety is a priority. The all-steel unibody construction is not only very rigid, it is also enormously strong. The crumple zones and ‘Triple H’ construction are designed to absorb and redirect energy away from the passenger cabin. ‘Triple H’ refers to the H-shaped structures in the sides, floor and roof that provide a rigid cell around the cockpit. Side impact door beams are also fitted, further to improve safety in a side impact. The Tribute HEV comes with advanced front airbags that use various sensors to deploy each front airbag with exactly the right amount of force to deal with the impact. Sensors measure the weight of the seat occupant, the force of the impact and the seat distance from the steering wheel. Side airbags, fitted into the seats rather than the doors – so they work equally effectively, irrespective of seat position – are standard. Front side-impact airbags, side-impact air curtains, independent multilink rear suspension and four-wheel anti-lock braking system (ABS) are also standard. Front three-point seat belts have pretensioners to reduce slack in the early moments of a frontal impact.
In the rear, all three seats have three-point seat belts and adjustable head restraints for extra safety. Providing additional safety and security, a tire pressure monitoring system is standard.
From Mazda
Attached Thumbnails 2008 Tribute Hybrid Electric Vehicle 'HEV' Pics-2008_mazda_tribute_h_015__preview.jpg   2008 Tribute Hybrid Electric Vehicle 'HEV' Pics-2008_mazda_tribute_h_085__preview.jpg   2008 Tribute Hybrid Electric Vehicle 'HEV' Pics-2008_mazda_tribute_h_088__preview.jpg   2008 Tribute Hybrid Electric Vehicle 'HEV' Pics-2008_mazda_tribute_h_132__preview.jpg   2008 Tribute Hybrid Electric Vehicle 'HEV' Pics-2008_mazda_tribute_h_137__preview.jpg
Old Jan 7, 2007 | 11:58 PM
ASH8's Avatar
Super Moderator
And...
Attached Thumbnails 2008 Tribute Hybrid Electric Vehicle 'HEV' Pics-2008_mazda_tribute_h_205__preview.jpg   2008 Tribute Hybrid Electric Vehicle 'HEV' Pics-2008_mazda_tribute_h_215__preview.jpg   2008 Tribute Hybrid Electric Vehicle 'HEV' Pics-2008_mazda_tribute_h_221__preview.jpg
Old Jan 8, 2007 | 10:12 PM
Aipex8's Avatar
X e p i A
I love the shots in front of the oil wells. I was under the mistaken impression that the Tribute was going away being replaced by the CX-7/CX-9.
Old Jan 8, 2007 | 10:33 PM
ASH8's Avatar
Super Moderator
I thought it was going to be called a CX-5....Zoom44?...
AFAIK this unit is US made at Ford (cant you tell) and won't be for export...
Apart from the "hybrid" I can not see the point.
I mean what would you rather own a CX-7 turbo 4 that is the latest SUV, or a Tribute that is 10 years old, had a make-over and looks it...
I think its bloody awful looking...and expect better from Mazda, but then again perhaps this is a Ford US decision.
Old Jan 9, 2007 | 06:27 AM
rotary crazy's Avatar
I dont think it looks that bad
Jst4fun
Apr 17, 2021 07:43 AM
New_Mazda_Guy
NW RX-8 Forum
Sep 19, 2019 11:20 AM
Rx8 VA Guy
Jun 4, 2016 12:42 AM
urbanvoodoo
Sep 30, 2015 12:41 AM
