Engine Cover
Old Sep 9, 2003 | 10:42 AM
rx-ache's Avatar
Engine Cover
Does the engine cover serve any useful purpose? Seems to me that with the need to frequently check oil consumption, it is just in the way.
The only thing I could think of that it might do would be to protect the hood from excessive heat. Do you think the paint on the hood might be damaged if it were removed permanently?
Thanks,
rx-ache
Old Sep 9, 2003 | 03:08 PM
mikeb's Avatar
100% Italian
I dont think the hood paint would get damaged. I think the cover is for looks so If you want to remove it for good I'm sure its ok
Old Sep 9, 2003 | 04:44 PM
dcfc3s's Avatar
RX-7 Guru
Yeah, it's really just for aesthetics, to make the engine bay cleaner looking.
If you do remove it, please hang on to it! In 10 years, people will be dying to have one . The battery box lids on 2nd gen RX-7's are usually missing due to incompetent previous owners, and they're not cheap new. It's just a shame when someone misplaces/throws out something like that.
Hell, the 2nd gen turbo RX-7 has a top-mounted intercooler that's ALWAYS in the way for a lot of maintenance things. Unfortunately, you can't pitch it . But, you do get REALLY good at removing it over time!
Dale
Old Sep 9, 2003 | 04:52 PM
Kawi's Avatar
Happy Owner
Doesn't also aid a little in sound muffling from the engine bay?
Old Sep 11, 2003 | 05:51 PM
Jazzman's Avatar
Originally posted by mikeb
..I'm sure its ok
Hmm... famous last words.. Well at least he's *sure*. heh
Old Sep 11, 2003 | 05:59 PM
brothervoodoo's Avatar
RainMan is Back
I remember reading that the engine cover "may" also assist with airflow.. don't know for sure..
EDIT:
Did a search and found this:
https://www.rx8club.com/showthread.p...t=engine+cover
Seems inconclusive if it's for looks or utility.
Old Sep 11, 2003 | 07:46 PM
mikeb's Avatar
100% Italian
put it this way, I'm keeping mine on
Old Sep 11, 2003 | 08:48 PM
Digisan's Avatar
Alpha Powered
The Mazdaspeed strut tower brace makes it impossible to keep the cover on. If the Mazda engineers don't need it then I think you should be just fine.
Strut tower brace
D-san
Old Sep 12, 2003 | 12:56 AM
mikeb's Avatar
100% Italian
wow 616 bucks
is that worth it
Old Sep 13, 2003 | 12:33 AM
canzoomer's Avatar
Forum Vendor
I asked a Mazda Canada rep, and he said it is required for airflow for cooling.
Truth or bullshit, I do not know, but he rather sternly warned me about leaving it off..
Old Sep 13, 2003 | 08:37 AM
Winning_BlueRX8's Avatar
Limecat's High Priest
same
I was told the same thing by my dealership. The cover aids in airflow and cooling.
Old Sep 17, 2003 | 12:09 PM
OverLOAD's Avatar
Hyper Space RX-8 _,.-^'`
It's definately not for cooling, it's right up against the hood..
I'd remove mine, but I'm pretty sure that it is actually a bit functional. It helps to keep the airbox in place, and also to keep the battery cover in place.
I think the engine looks tons better without it tho, I'm always taking mine off. When I get a new air intake, I'll probably keep the cover off...
OverLOAD
Jesus Martinez
44
May 6, 2025 08:09 AM
vapor2
Nov 3, 2020 03:38 PM
ShadowDragon78
Aug 21, 2015 03:29 PM
ShadowDragon78
Aug 11, 2015 06:42 AM
MolecularConcept
Aug 9, 2015 04:46 AM
