Spare Tire? Car Cover?
Old Sep 6, 2003 | 02:46 PM
eccles's Avatar
Prodigal Wankler
Re: Spare Tire? Car Cover?
Originally posted by JamesJKelly
I have just recently ordered my RX-8. I did not get the spare tire kit with it and am now having second thoughts. What actually comes with the car? Is there any need to get this extra option?
The RX-8 comes with Mazda's "Instant Mobility System" which comprises a bottle of sealant and an air compressor. Combined with Mazda's roadside assistance, this is probably sufficient for owners who don't intend to venture too far off the beaten track. But if you plan on getting away from it all in your RX-8, you may feel better with the added security of a real spare tire.
Old Sep 6, 2003 | 08:05 PM
claude4's Avatar
I take it that if one uses theis repair kit, it would render the tire useless and unreusable, even if they could fic the cause of the leak?
Rim could be cleaned, right?
Claude H.
Old Sep 6, 2003 | 10:19 PM
eccles's Avatar
Prodigal Wankler
Originally posted by claude4
I take it that if one uses theis repair kit, it would render the tire useless and unreusable, even if they could fic the cause of the leak? Rim could be cleaned, right?
That appears to be the "party line" from Mazda. According to the Owner's Manual:
A tire that has been temporarily repaired with the tire sealant cannot be reused. Mazda recommends replacing the tire with a new one.
The wheel can be reused after any sealant adhering to it is wiped off and carefully inspected. However, replace the tire valve with a new one.
Old Sep 7, 2003 | 04:19 PM
eccles's Avatar
Prodigal Wankler
But, rendering a $200+ tire useless may be reason enough.
Bear in mind that that the owner's manual is vetted and munged by Mazda's legal department before it goes to press. Chances are that a competent tire shop may be able to repair a tire that has been "gooped," but the lawyers won't let them suggest that possibility.
Old Sep 7, 2003 | 05:13 PM
ggreen29's Avatar
Interesting. I don't recall the cost of the spare tire kit. But, rendering a $200+ tire useless may be reason enough. Then the only question is how much space it takes in the trunk. As long as my golf clubs still fit, I'm happy (assuming they will fit at all )
Spare tire is US$395. I've got the spare tire option and it doesn't extend at all into the rearmost wide portion or into the well. It does take up most of the portion right behind the rear seat. I'm fairly sure that you'll get at least one golf bag in there, but I'm not sure about two since I'm not a golfer. Overall I was quite pleased and surprised with the amount of room that was still available after the tire mount and tire were installed.
And as for the road rescue kit & Mazda road side service, if you get a catastrophic tire failure will Mazda's road side service do anything other than call a tow truck and tow you to a nearby tire store. Or does roadside service normally carry a spare? At least with my own spare I'll be able to limp home with some dignity. But maybe I'm overthinking this thing.
Old Sep 7, 2003 | 08:10 PM
carnut's Avatar
I try to carry those little rubber tire plugs with a reamer and an insertion tool. I've used these for years with no trouble. The fine print on the package says a regular vulcanizing patch should be used inside the tire later, but all the tire shops around here just repair them with the plugs. Since the car comes with a compressor, you don't have to buy a little one for your trunk. You'll save a lot of time and money repairing the tires yourself. Another great thing about these plugs is that you won't ruin the tire! Make sure you keep a pair of pliers around to pull out the offending nail. You'll usually see the nail. If not, spread some soapy water (or saliva, if you're on the road) over the suspicious looking spot. If it bubbles, you've found your leak.
Old Sep 8, 2003 | 06:44 PM
Charles Cope's Avatar
Can you post a pic?
Old Sep 9, 2003 | 05:58 AM
Squidward's Avatar
Bottom feeder
As for the car cover, I think it's ridiculously over-priced... So what if it is designed to fit the RX-8 perfectly... no way jose.
Aftermarket covers do just as good of a job protecting your car and cost only. I bought a $40 cover for my TT that worked great.. An $80 cover (I don't think there are aftermarket covers that even cost that much) should work even better... but $250??? c'mon, give me a break.. I would be embarassed to be seen with it, simply because I know how much it costs, it's a pretty wasteful investment.. You're better off spending that money on several botles of Zaino and a 1400psi Karcher pressure washer...
Old Sep 9, 2003 | 09:12 AM
spypondtom's Avatar
fyi, i opted for full size tire and rim in trunk. it eats up much space but will comfort me on long trips and i can remove it when i am local. i called mazda roadside service and they will only come and tow you to dealer. they do not carry spare tires or donuts. by the way, a new tire is 200 dollars from tire rack and a rim is 280 from mazda. i also have the green you ordered-it's elegant. have not seen another in massachusetts.
Old Sep 9, 2003 | 10:49 AM
Wasy's Avatar
Wow! Those replacement tires are expensive, but I am not overly surprised...
Speaking about tires, however, has anyone checked into SNOW tires yet? Yup, SNOW! In the past with my Miatas and RX7's I have mounted FOUR matched, balanced and alligned snow tires to survive New England winter driving. Not sure about the availability of snow tires for these 18" rims but I haven't started looking yet. Any other thoughts? Some of us WILL be driving in snow this winter!!
Jesus Martinez
44
May 6, 2025 08:09 AM
D13
Aug 22, 2015 11:42 PM
Kahl
Aug 20, 2015 11:49 PM
RXeckless
Aug 16, 2015 12:52 PM
akagc
Aug 11, 2015 07:07 PM
