pressure plate broke or so im guessing
Old Dec 6, 2006 | 06:20 AM
RX4life's Avatar
well started up the 8.. this morning and apparently my clutch pedal had no hydraulic pressure..
this was odd as there was no sign of leaking or increasing difficulty in shifting..whihc is common to the failiure of master or slave cylinders
ive been having clutch engagement problems in lower rpms for some time mazda ignored it ..
and it now appears that the pressure plate must be broke according to me ..
towed it to mazda and they thiught that they could scam me by blaming the clutch disk..i told them there is no way clutch disk cause the symptoms..
anyaways anyone else have pressure plate problems??
Old Dec 6, 2006 | 08:34 AM
9291150's Avatar
Nope. Just an annoying squeak every time I depress the clutch.
Good luck with your issue! I'm waiting on a new tranny, but clutch is fine.
Old Dec 6, 2006 | 08:51 AM
-=drift=-'s Avatar
TRUST PWRD
i doubt it was the pressureplate. could be the reilive valve in the mater. mine went on my 7 and the pedel just hit the floor. pressure plate failures wouldnt lets you start the car, or would shred the bellhousing up before exploding.
Old Dec 6, 2006 | 06:53 PM
YT1300's Avatar
Turning and burning
Not that pressure plate. If that goes, you can't start the car, last time I checked.
Might be a line or the cylinders. Your previous clutch problems might have been a symptom.
Old Dec 7, 2006 | 01:19 AM
RX4life's Avatar
oh isee thanks...nevertheless damn Wolfe Mazda tried to scammmmm meee
thanks guys will let them know..
Old Dec 11, 2006 | 09:07 AM
SOSECSI's Avatar
Hey 9291150..I have that EXACT same problem with my clutch when up or downshifting. I took it back to Prima mazda and all they did was lube the cable or something. Still there though.....
Old Dec 11, 2006 | 04:16 PM
YT1300's Avatar
Turning and burning
Isn't there a TSB on that squeaking clutch problem?
Old Dec 12, 2006 | 01:56 PM
92tsiawd's Avatar
Sounds like a clutch master cylinder
Old Dec 12, 2006 | 03:25 PM
9291150's Avatar
Not to hijack the thread, but I did a search on the clutch squeak and here are some observerations.
Can you tell if it is coming from the clutch pedal itself (inside the car) or is the noise coming from outside the cabin (under hood or under car). I've had two older Hondas with squeaky clutch pedals. One car was a cable operated clutch and the other hydraulic, both turned out to be the return spring sheaths on the pedals themselves.
My dealer lubrictaed the slave cylinder and the squeak is gone. At least that is what they said they did.
I have the same problem and the dealer tried to fix it 3 times. The dealer lubed the slave cylinder first, but it didn't work, so they told me to come a week later and they will replace the whole pedal assembly. When they replaced the clutch pedal, the squeek was gone for 1000 miles and returned with a louder squeek. The service manager had it lubed again, but the problem still existed and he told me he doesn't know what to do anymore. The service manager then told me that a TSB might come out on a new clutch pedal, but he also told me not keep my hopes up because he was just speculating since so many people have this problem. **To note: My service manager had a RX8 with the same squeek problem so he was real helpful and he couldn't get it fixed either.
Buy a can of ATE Super Blue, take it to your service manager and tell him to replace the fluid in the clutch hydraulic system. This took care of that same problem on my RX-7. It may not work on your car, but it won't cost you much to try.
The squeeky pedal is just because you need lube on the spring.. Just stick yer head under there, find your clutch and follow it up. Get a can of silicone lube and give it a quick spray. Ive been squeek free for 25k miles now..Dont use WD40, it attracts dust.
I had the same problem after about 500 miles on my '06 GT. The dealer replaced the clutch pedal assembly and the problem has not come back.
I had my clutch pedal replaced last week for a squeak. The squeak is gone and the clutch works nicely, although I noticed that it has to be held right against the floor for the car to crank. I never noticed this before, although I've only had the car for a month.
How high off the floor can you hold your clutch pedal before the starter interlock won't allow the car to crank? There are 4 possible sources of noise that I found,the pedal pivots,the clutch cylinder,and 2 switches---in my case a push rod on the lower switch was making the noise and some silicone grease quieted it.
You have to get right into the footwell and identify the source for your car.
I crawled ainto the footwell with my troublelight and relocated some of the silicone grease that they liberally applied to my clutch pedal assembly onto the switches and clutch cylinder and the squeak is gone (at least for now!).
Don't know what works though, haven't tried. DarkBrew had this problem, wonder if it was resolved.
Old Dec 23, 2006 | 11:11 AM
ROCKSTAR RX8's Avatar
Retired...
I've been having problem with my tranny as well.. after the dealer changed my tranny fluid I have problem shifting from 3rd to 4th.. and I demand a NEW TRANNY now... said they were gonna rebuild it... I doubt a rebuild unit by the store is gonna hold..
Old Dec 24, 2006 | 12:22 AM
9291150's Avatar
Just got a new tranny for that exact problem (car is 16 months). Keep fighting.
Most wouldn't have the expertise to rebuid it anyway.
Old Dec 24, 2006 | 12:23 AM
9291150's Avatar
Yeah, they lube'd mine too...once again, still there!
Old Dec 24, 2006 | 12:56 AM
I'd really like to see the cable that they supposedly "lubed". If you paid for it...it was your wallet they lubed
Hydraulic clutch.......no cable.
They might have lubed the pedal and bracket?
Old Jan 2, 2007 | 07:42 PM
Retired...
Finally dropped off my car at the dealership today waiting to get the tranny operation done!!
I demanded a new tranny however, Mazda Canada declined it said they'd only rebuild it. The service manager did tell me that they will open up the tranny first and will try to convince Mazda Canada to give me a new tranny instead of the gears... guess we'll see what happens!
cliffkemp
Dec 24, 2024 10:48 AM
05rx8mazda
Nov 28, 2015 09:42 AM
