Go Back   RX8Club.com > Series I Tech & Performance > The Tech Garage
Old 12-05-2006, 08:30 AM   #1
Ronn
How to remove the air ducts from the PCM housing???
Hello,
I want to send my PCM out to Racing Beats but had difficult time removing the 1st air duct (the one on the left) from the PCM housing. It was a pain in the rear removing the top cover off the PCM. Those taps were very fragile and I think I broke everyone of them. I managed to remove the PCM out of the housing without having to undo the 1st air duct but eventually I will need to know how to do that before I get the PCM ship back from Racing Beats. Anyone that had done this task before please show me how to remove this dang air duct. Thanks.
Ronn is offline   Reply With Quote
Old 12-05-2006, 09:25 AM   #2
StealthTL
Super Moderator
StealthTL's Avatar
Keep tabs.....
The tabs are pretty tight, but should yield to a flat blade screwdriver - just make sure it's a warm day or a heated garage, if they're cold they are brittle and may snap off.
I've had the ducts out a couple of times for various reasons, and never noted them as too tough....
S
Mobil1 is expensive, but no oil costs more......
StealthTL is offline   Reply With Quote
Old 12-05-2006, 09:38 AM   #3
nycgps
A FC3S and SE3P guy
Get a hairdryer , blow it directly around that area for maybe 10-15 minutes.
After that its easy to take it off.
Dont try to force it out when its cold, cuz its going to snap off like ^^ said.
nycgps is offline   Reply With Quote
Old 12-05-2006, 10:34 AM   #4
dannobre
Back is Back...Front next
Why do you need to remove the air ducts?? just open cover and unscrew the brackets...remove PCM from the plastic case...send it in. You don't want to send them the whole case???
dannobre is offline   Reply With Quote
Old 12-05-2006, 10:53 AM   #5
Ronn
Thanks guy for the reply. It was 5 degree in the garage last night so I snapped those tabs left and right. I removed the PCM out without having to undo the air ducts last night but it would be easier to put those screws back on if I can have the housing outside the engine bay. Must be the cold temp that cause all the difficulty in removing those tabs/air ducts.
Old 12-05-2006, 11:27 AM   #6
Brettus
K1W1 300 club founder
Brettus's Avatar
Another idea wpould have been to do the job after going for a drive . Does not take much to get everything hot under there.
Brettus is offline   Reply With Quote
Old 12-05-2006, 01:46 PM   #7
Trekk
Goat rider
Trekk's Avatar
Send a message via Yahoo to Trekk
I just sort of jammed a flat head into mine and ripped it out. The tab broke but who cares once it's bolted in it has no place to move anyways.
Trekk is offline   Reply With Quote
Old 12-05-2006, 02:49 PM   #8
Ronn
Yes, I jammed a flat head screw driver in there too but mine didn't come off like it supposes to....I will tried again tonight. I will ask the neighbor for a hair dryer and see if some heat will help.
