Simple subwoofer/amp solution?
Old Nov 23, 2006 | 05:48 AM
yellowrx8inoz's Avatar
'06 Nats coolest car!
Check this out folks - I was wondering if it would be a good idea for our cars. It could sit in the recess in the boot as it's only 110mm high - and it's plug and play.
EDIT: Just checked the dimensions (600x380x110mm high) and it would be a VERY nice fit in the recess!
CLICK HERE FOR DETAILS
Note the ad shows a significant discount for 5+ units ($159.95 instead of $199.95) so we could do a group buy!
Can someone with more tech/audio knowledge comment on its specs? I'm sure it's not kickass but it could still be a worthwhile addition...
Attached Thumbnails Simple subwoofer/amp solution?-productlarge_9752.jpg
Old Nov 25, 2006 | 04:41 PM
Bump - any thoughts, anyone?
Old Nov 25, 2006 | 06:21 PM
RXVIII's Avatar
Zoom Zoom Zooooooomm Psst
Out of my league Will!!!
Whereabouts were you planning to place it?
Old Nov 25, 2006 | 06:50 PM
dbb's Avatar
dbb
DSC Disabling Officer
What do you find wrong with the stock BOSE system?
Anyway,
> RMS power: 75W
>Variable low-pass electronic crossover: 40Hz ~ 600Hz
40Hz is a pretty crappy low end frequency for a subwoofer. If we assume 20Hz is a the lowest end of human hearing, and you can generally "feel" the sound pressure a little below that, then that unit is below par. AFAIK the standard BOSE system has better low end response than this. The factory sound seems , to me, to be lacking top end - so maybe replacing the tweeters would be a better "first option" for a sound system change ...
If you like rock groups or country or jazz, then it might be ok - but if you like minimal techno / drum and bass / deep house / or other music with an emphasis on sub bass, then steer clear.
This unit here is a good example of the sort of specs you would be looking for if you wanted to see a dramatic improvement on the factory BOSE system (note : assuming leather pack sound system). Admittedly, it is a lot more expensive - but the rx8 is a fairly expensive car - so I am assuming you can raise the cashola.
http://ecoustics.pricegrabber.com/se...sterid=6396577
ie. 10 Hz, 500W RMS.
There are also plenty of discussions in the "Interior, Audio, and Electronics" section of this site with detailed technical discussion of the most effective ways of upgrading the rx8 sound.
Old Nov 25, 2006 | 07:08 PM
RX8ted's Avatar
Back in Black
Here's a possible solution?????????
Attached Thumbnails Simple subwoofer/amp solution?-image1.jpg
Old Nov 25, 2006 | 07:12 PM
dbb's Avatar
dbb
I like the rice cookers where the back seats are supposed to be.
Old Nov 26, 2006 | 07:50 PM
^^^ thanks dbb - looks as though it's not worthwhile then.
Old Nov 26, 2006 | 08:40 PM
Now that's more like it LOL
Old Nov 27, 2006 | 03:33 AM
Black-8's Avatar
Rotary noob
I wouldn't put any subs in the car, it's just adding to the weight :D
Old Nov 27, 2006 | 08:38 PM
takahashi's Avatar
Don't worry the vege burger that Will eats will save some of that!
Old Nov 27, 2006 | 08:45 PM
Yep, I have a natural advantage over some of youse on here LOL
OnebaddRx8
Aug 25, 2019 11:34 PM
Jelliott5384
Oct 26, 2016 05:15 PM
Evan Gray
Nov 24, 2015 01:00 AM
Evan Gray
Sep 26, 2015 12:30 PM
p8ntman442
Sep 23, 2015 09:18 PM
