Front speaker failed. What to check?
Old Nov 21, 2006 | 03:00 AM
Yusik's Avatar
I just noticed that my front left(driver's side) is not work. Does anybody know the way to check amplifier in door or head unit, what is wrong?
Old Nov 21, 2006 | 03:23 AM
BoosTED's Avatar
If you pull the interior panel off of the door you should be able to tell if the speaker is dead by moving it in and out (it won't move much and will sound really bad like there are rocks in it.
I had one seize up on me.
If it is electrical you can use a multi-meter to see if it is getting voltage at the speaker.
Old Nov 21, 2006 | 04:04 AM
Yusik's Avatar
Yes, it electrical problem I suppose, I have an amplifier from door in office now to write down its ##, speaker it seems to me is well. I need to know what connectors/wires I should check. To specify, what wires which goes from head unit to door amplifier need to check to define faulty part for sure
Old Nov 21, 2006 | 11:59 AM
BoosTED's Avatar
The pin out is looking at the connector with the release button up.
Going left to right, top first.
First one (w/r) goes to the battery (+)
next 4 are empty
last on the top is positive to the left front tweeter (R)
Starting from the left on the bottom:
Ground (-) to battery B/Y (R)
Signal from the main amplifier (R/W)
3 blank then the last on the bottom is tweeter (-)
The diagram for the front speaker off of the door amplifier shows only number 1 and 2 it doesn't have the wire colors.
So for the front speaker:
The plug that the speaker connects to.
The pin closest to the button to release the connector is negative.
Furthest from the button is positive.
Old Nov 22, 2006 | 12:53 AM
Yusik's Avatar
Thank you 4 years to Supercharge!
Hope I have time this evening and check it immediately.
Warrior777
Jun 24, 2019 04:47 PM
drebbrnator
Dec 27, 2018 07:02 PM
fullsmoke
Nov 24, 2015 04:09 PM
akagc
Aug 11, 2015 07:07 PM
Majictoast
Jul 18, 2015 06:45 PM
