Nasty sound after startup (it's not the ABS test!)
Old Nov 19, 2006 | 05:16 PM
Revolver's Avatar
Shootin' from the hip
I've noticed in the past couple of weeks a nasty, sudden graunching/thump kind of sound a second or so after the engine kicks over. It seems to be coming from the engine bay area. The car is still stationary when it occurs.
The weird thing is, it's not every time I start the car. My car is usually garaged but on Mondays and Wednesdays it's out in the sun all day. It's happened when starting the car up in the late afternoon on a couple of those days. The interior of the car is quite warm.
It's quite noticeable, to the point of exclaiming 'WTF was that?!' and getting out of my car and checking under the bonnet when it first occurred.
First thoughts are that it is the A/C compressor turning over. Should I get it checked and are there any other suggestions?
The car is otherwise running fine and I have no warning lights or other signs of a problem. The A/C appears to be running fine too. It is an '04 manual.
Old Nov 19, 2006 | 05:19 PM
takahashi's Avatar
I wonder if the timing belt and other thing hitting a loose object. But then you have a loose object, you could hear it while driving.
Unlikely the engine itself, there are not many loose engine parts in there? At least you cannot blame the valve like in the piston engine.
I would say get a good torch and look around, get someone to start the engine for you while you are looking.
Old Nov 19, 2006 | 05:23 PM
Revolver's Avatar
Each time it's happened, it's only made the sound once and at about the same time after startup. Sounds perfectly normal after that and while driving. I did have a good look around under the bonnet but couldn't see anything amiss.
Old Nov 19, 2006 | 05:34 PM
azzaboynt's Avatar
is your aircon on when you start the car up?
Before I shutdown the car out of force of habit i turn off the aircon and radio.
Old Nov 19, 2006 | 05:38 PM
Gomez's Avatar
Shifty Bastard.
Well it's not the timing belt, of that I am 1000% certain. The Rotary engine does without such trivia......
This sound occurs during start..........or just after the engine starts? A metallic sound? No stray tools under the hood? (other than the quizzical one looking for a strange sound )
Old Nov 19, 2006 | 05:41 PM
1145climber's Avatar
RX-8 Enthusiast
whats the ABS test?
yellowrx8inoz's Avatar
'06 Nats coolest car!
Dave, I've been getting something like this too (occasionally on starting from cold) and I reckon azza's got the answer. See if it happens when a/c is left on, or off?
Will
Old Nov 19, 2006 | 05:53 PM
azzaboynt's Avatar
Originally Posted by 1145climber
whats the ABS test?
you may notice when you start your car and first take off, there is small clunk sound when you reach approx 6km/hr, or if you have your foot on the brake (steep driveway) then the brakes shudder slightly. only happens once on startup.
Old Nov 19, 2006 | 06:03 PM
Gomez's Avatar
Shifty Bastard.
Whatever it is, it doesn't seem serious. If you want to track it down, you'll need to be under the bonnet while someone else starts it.
Good thing is, you're still under warranty. If it's a heat related issue it'll surface this summer. Now.......where's the champers? Oh, here it is......cheers!!
Old Nov 19, 2006 | 06:10 PM
Gomez's Avatar
Shifty Bastard.
It will happen in reverse too, if that's the way you first travel after starting the car. About 6mph (10kph), according to the manual..... .
Old Nov 19, 2006 | 06:15 PM
Revolver's Avatar
I can't remember if it's been on each time or not (it's happened about 3 times now).
I know the aircon is on atm and the car is outside in the sun all day today, so I'll see what happens when I start it up after sailing this evening.
Mind you, I've started the car plenty of times with aircon switched on previously and it's never made this sound before. As previously stated, it's not a minor mechanical sound. It's a quite audible thump and I've never heard it before, so I'm concerned something might be struggling and want to identify it before warranty expires (I've got a year to go though).
Old Nov 19, 2006 | 06:22 PM
Revolver's Avatar
It's not during start. It's a second or so after the engine starts, which is usually when the A/C jumps into life (hence my suspicion as to an A/C related cause).
Doesn't sound metallic as such. More a graunching/thumping kind of sound.
No stray tools that I'm aware of. Mine's married.
I changed my oil cap after the Nationals (to a shiny Mazfix one ) but I can't see how that could be causing a noise. If it was, surely I'd be hearing it either once only or each time I start up.
Old Nov 19, 2006 | 06:23 PM
Revolver's Avatar
Will
Will do Will.
Old Nov 19, 2006 | 06:32 PM
MACCAA's Avatar
Check for Possums....
Old Nov 19, 2006 | 07:06 PM
takahashi's Avatar
LOL
Old Nov 19, 2006 | 07:59 PM
Revolver's Avatar
I expect more constructive advice from my Melbourne co-driver .
Old Nov 19, 2006 | 08:49 PM
labrat's Avatar
I'd like to add my vote to an A/C-related noise. It could be a vapour lock in the system. I've heard that sound on some fridges we've had too.
The advice to turn off your A/C before switching off the ignition has merit. It does help to decrease the load on the battery when you start the car as well.
Old Nov 19, 2006 | 09:19 PM
Grizzly8's Avatar
Dave
Misfiring starter motor not cranking up properly due to weak battery .
At least its not ticking ............ (disgruntled client )
Old Nov 19, 2006 | 09:25 PM
Revolver's Avatar
Originally Posted by MissyK
Am I missing something??
MACCAA said he might join me for the Victorian sojourn. Reckons driving for 10 hours each way to go on a one day cruise also suits his mentality .
Would that be okay with the Vics?
Old Nov 19, 2006 | 09:27 PM
Revolver's Avatar
Yes, that's sound advice but I don't always remember to do so.
And as posted previously, my concern is that this is a new phenomenon, and perhaps a harbinger of failure somewhere.
Old Nov 19, 2006 | 09:28 PM
Revolver's Avatar
Originally Posted by Grizzly8
Dave
No Michael, the car is starting without a problem. I've had the starter motor, battery and plugs upgrade too.
As for disgruntled clients, never had one.
Old Nov 19, 2006 | 09:30 PM
Revolver's Avatar
I'm hoping it's something like this and is merely an isolated, occasional problem.
Guess I'll find out this evening.
