Suicide door stuck
Old Nov 2, 2006 | 12:32 PM
acc3d's Avatar
Exclamation Suicide door stuck
Anyone ever have trouble opening one or both of the rear doors? For no apparent reason, my rear driver's side door will not open. It's latched shut and I can't figure out why. I tried playing with the seatbelts to make sure they didn't trip the lock system, but to no avail.
Any advice?
Old Nov 2, 2006 | 12:40 PM
no dice's Avatar
I bomb atomically
check your fuses
Old Nov 2, 2006 | 12:44 PM
XRX8X's Avatar
more then a Mazda
never had mine stuck before but be sure the belt is not looped in there.also check and be sure that it is completly closed first then try to open it again.mazda made a pretty good door assembly and i have not heard of any problems yet!good luck(two years and 34,500 miles and running!
Old Nov 2, 2006 | 12:47 PM
XRX8X's Avatar
more then a Mazda
not to be a smart a** but i do not belieave there are any fuses or electrical funtions with the rear doos on the 8 but i could be wrong(no wires in or out of the door)
Old Nov 2, 2006 | 12:50 PM
but the seat belt tensioners...
Old Nov 2, 2006 | 12:56 PM
no dice's Avatar
I bomb atomically
and The Man has spoken
Old Nov 2, 2006 | 01:24 PM
acc3d's Avatar
So then we conclude that there must be a malfunction in my belt tensioner? I made sure the belt was retracted all the way and not caught on anything. Time to call the dealership I guess. Thanks for the suggestions guys.
Old Nov 2, 2006 | 01:38 PM
Aseras's Avatar
press the dorr button switch. does it make a click when you push it in or not? if not the pin could be getting stuck.
Old Nov 7, 2006 | 12:48 PM
acc3d's Avatar
After a trip to the dealership it turned out that the cable that pulls the latch was disconnected. Possibly the result of vibrations from driving on really bad roads?
Jst4fun
Apr 17, 2021 07:43 AM
Jst4fun
Mar 5, 2021 07:16 PM
nferguson88
Oct 6, 2015 12:45 PM
Learners_Permit
Sep 27, 2015 07:38 PM
