unichip or e-manage or re-map?
Old Oct 29, 2006 | 12:37 AM
Fluid4's Avatar
Simply Red
which is better?
care to share?
Old Oct 29, 2006 | 01:38 AM
madmax_rx8's Avatar
Correct me if i'm wrong but this is what i know.
unichip rx-8 cannot use...
E-manage need to have the special one.. ask coupe07 i think only they carry the special type
re-map cannot tune up your air fuel ratio which is one of the important thing when you talking about tunning.
regards
Kelvin Koh
Old Oct 29, 2006 | 01:56 AM
cuscorex's Avatar
爆 走 RE风 林 火 山
fr wat i gathered,onli the fcon-IS is able to bypass the 'loop sys' in our ecu;juz like in toyotas...
Old Oct 29, 2006 | 03:45 AM
CoupeM's Avatar
Night Rider
From what I have read up...unichip can be used on the rx8. Taka installed unichip on his 8 but from his writeup, it was abit disappointing. Emanage ultimate have recently released software ver 2.0 This update is suppose to address the problem faced by the earlier versions. According to mazdamaniac, emu can be used on the 8 as well and infact is now problem free. There is a way to force the ecu into open loop. As for the emu that RE uses and is said to be different from the emu that you can buy outside...well...it looks the same on the exterior but interior...i dunno. The japs like to hide hide hide...hahahaha.
Remap does tune up the afr and ignition timing. If not you pay so much money just to turn on the radiator fan early for wat? Mazsport got a cooling kit that turns on the fans early as well and prob cost a fraction of the money spend on remap. I think the ecu remap does tune up the afr and timing. But since it is not dyno tuned, my assumption is it is a target afr tune like some piggybacks or standalone with the function to auto tune to the target afr you set.
Actually...the search button is your best friend. Dun be lazy. kekeke
Old Oct 29, 2006 | 05:44 AM
coupe07's Avatar
SC 300HP!!
the e-manage ultimate by re-a is special becos a special chio is implanted inside. U will not find this e-manage ultimate anywhere in the market. Using the e-manage ultimate to tune ur NA setup is easting ur money. How much horses do u wan to gain from it?? Do u tink a NA setup can free up 30 horses???
Unichip wise, can use, but minimal gain.
The remap, as wat coupeM says, does more than speedcut and turning on ur raditaor fan early. Ignition timing and AFR oso are tuned and optimised to NA setup.
As to wat is best, go to someone whom u deem noe ur car best.
Old Oct 29, 2006 | 07:27 AM
CoupeM's Avatar
Night Rider
Tat would be Monster Garage! kekeke
Old Oct 29, 2006 | 07:46 AM
rx_king6668's Avatar
i think i'll go for remap
Old Oct 29, 2006 | 08:59 AM
sqflyer's Avatar
Heavy Machinery Operator
Not meant as a flame, but since u asked to be corrected...
"unichip rx-8 cannot use..." Wrong, a few local 8s are running with unichips... improvement is not a lot because at the end of the day, all are NA setup.
"E-manage need to have the special one.." Wrong, EMU as stated by CoupeM
"re-map cannot tune up your air fuel ratio" Wrong, tuning the A/F and ignition is the whole point of doing a remap, along with a couple of other side benefits.
Good that you check what you know with the rest of the guys here... we're all here to learn more about the car we love afterall.
Old Oct 29, 2006 | 09:02 AM
lennon's Avatar
Good one..... You busted him kau kau....
Old Oct 29, 2006 | 09:42 AM
sqflyer's Avatar
Ha ha.. that's why I stated right from the start that it's not meant as a flame. Just seems like he got misinformed by his sources. Anyway, good that we all ask and share information so everyone can benefit from collective knowledge.
Old Oct 29, 2006 | 11:32 AM
Fluid4's Avatar
Simply Red
As to wat is best, go to someone whom u deem noe ur car best.[/QUOTE]
i also guess must be monster liao...heehehe...
so wat u suggest?
emanage or remap?
btw mine is 5mt.....
Old Oct 29, 2006 | 01:09 PM
lennon's Avatar
Majority choose remap....... end......
Old Oct 29, 2006 | 01:12 PM
coupe07's Avatar
SC 300HP!!
so wat u suggest?
emanage or remap?
y do u wan to waste money on the e manage when ur stock ecu can do wat e manage can do???
it doesnt matter wat model ur car is.... juz ask eugene from mazda motors wat the remap has done to his 5mt...
Old Oct 29, 2006 | 08:42 PM
Fluid4's Avatar
Simply Red
gain alot?
Old Oct 29, 2006 | 08:45 PM
Fluid4's Avatar
Simply Red
sorry for being a new..
but after remap then lata if i change my exhuast,air filter,fuel regulator...etc n other mods...
will it everything go cork up?
coz what i noe is that the ecu is the last ting to do after all the mods i wanna do....
is that rite?
remap gain lot?
Old Oct 29, 2006 | 09:06 PM
derekwcw's Avatar
is that rite?
remap gain lot?
Fren, like what I told you on Fri nite, minor mods like exhaust, and air filter won't affect the remap.
As for fuel regulator, don't even touch touch it, the 8 wankel is not like those 4 cylinders.
As for gains, its NA, not much gains, more of optimisation of the current stock ECU. You want alot of gains, go for Force Induction.
Or want more gains from NA, VTEC is the only and best option for a NA car...
Old Oct 29, 2006 | 09:54 PM
Fluid4's Avatar
Simply Red
okie....then i try to put vtech on top of our rotoray then...hahahhahahaaa
thankz for the info.....
Old Oct 29, 2006 | 10:02 PM
coupe07's Avatar
SC 300HP!!
is that rite?
remap gain lot?
the remap is ALREADY catered to you changing ur intake, all the way right up to your exhaust. Even if you dun change, u dun have loss of power. If u change, u gain the power. ie if u change the right exhaust manifold, cat and exhaust.
Take note, exhaust system = intake, exhaust manifold, catalyser and exhaust.
If u do anything else, like meddle with the fuel pump, dun come n blame the remap like some kuku oil rep who come and blame the remap when his engine oil cannot burn in the rotary engine.....
Old Oct 30, 2006 | 03:28 AM
Emperor's Avatar
aka Spectre
Who is the kuku oil rep?
Old Oct 30, 2006 | 04:21 AM
CoupeM's Avatar
Night Rider
Must be a bird..cause i only know of kuku bird. :P
Old Oct 30, 2006 | 04:35 AM
madmax_rx8's Avatar
[QUOTE=sqflyer]Not meant as a flame, but since u asked to be corrected...
QUOTE]
Bro tks for clearing the air... if not then the rest of the forumers will be misled by me.
Anyway don't worry.. it's for sure not meant as a flame as we are all here to learn new things..
But what i have said before is what i heard from those workshop that i been to. perhaps those were old info and i never did follow up..henceforth still carry the old info with me hahaa
regards
kelvin Koh
Old Oct 30, 2006 | 10:05 AM
coupe07's Avatar
SC 300HP!!
erm... kuku oil rep lor... no point stirring **** again..
Old Oct 30, 2006 | 11:22 AM
sqflyer's Avatar
u mean kuku oil rep is shitty? heh heh... *stir stir*
Old Oct 30, 2006 | 08:52 PM
coupe07's Avatar
SC 300HP!!
there..... that one lor.... u tot is from USA then end up find out from spore lor....
Old Oct 30, 2006 | 09:05 PM
Drifter's Avatar
You mean Texas oil is not from USA??
Damn ! ...
