added 1/2 quart after 800 miles- bad?
Old Sep 2, 2003 | 03:46 PM
emailists's Avatar
I did a 500 mile roadtrip with the car (6 speed) the first weekend I got it, and had no dip in oil levels. the week and a half since then I have done 300 city miles, and the dipstick was halfway between F and L. I added almost a half a quart, and oil level went back up to close to full. City driving includes lots of stop and go, and some idleing. any thoughts if this is way out of line for oil usage?
Old Sep 3, 2003 | 02:46 AM
Squidward's Avatar
Bottom feeder
it could also be a timing issue that is causing the car to burn more oil than necessary.. Definitely have your car checked out.
I've driven my car 1300 miles now and the oil use has been negligible.
Old Sep 3, 2003 | 02:57 AM
Superbone's Avatar
emailists, I had the same issue as you. Did you see your oil light flash? Mine also was a 1/2 quart low.
Took mine to the dealer and they ordered a new oil pan and said they would upload some new software as well when installing the pan.
Old Sep 3, 2003 | 05:45 AM
RX-8 2004's Avatar
No Oil Added yet
I have not had a problem with my oil. I have a little over 1000 miles and it is still showing FULL.
Old Sep 3, 2003 | 05:47 AM
emailists's Avatar
Yes I saw the oil light flash a few times when crusing in 4th gear.
I guess this is no reason to do the buyback and get another8, is it?
Old Sep 3, 2003 | 11:45 AM
brothervoodoo's Avatar
RainMan is Back
Re: added 1/2 quart after 800 miles- bad?
I've had the same experience. At around 700 miles I checked my oil for the 1st time (yes i'm bad). It was half-full so I left it alone. I then checked somewhere between 1400-1800 miles and noticed it was at the first hash mark (empty for lack of better word). From empty to the top hash mark it took a full quart to fill-up. I'm over 2200 miles now, I better check it again. I'll let you know where the oil level is now if you are still interested. FYI: I've never experienced the "oil light" indicator even when it was low.
Old Sep 3, 2003 | 08:16 PM
emailists's Avatar
would this worry anyone enough to consider a buyback, and get another 8?
I am testing gas milage now with sunoco ultra 94 and milage seems like it will be pretty poor. I'll know in a few days.
Old Sep 3, 2003 | 09:09 PM
JJFlash's Avatar
I am really on the fence about the repurchase. My 8 is using a lot of oil and getting poor gas mileage. One day I want to send it back, the next day I want to keep it. Everything about the car is perfect except the inconsistencies in everyones oil use and gas mileage. I'm worried I'll be dumping bucks into this engine soon after the warranty is up. That shouldn't be an issue on a $33K automobile.
Old Sep 3, 2003 | 09:19 PM
XUrotaryrocket's Avatar
why is everyone so paranoid about this damned engine ????
i've said it a million times and i'll say it again...... rotaries are perfectly reliable (as long as you check fluids regularly and aggressively maintain them). What you CANNOT do is treat it like a Honda Civic and expect it to go for 10,000 miles being low on oil. Rotaries with TURBOS have problems.
it's fine.... it was NEVER expected to get good gas mileage and it WAS expected to use oil
drive it, love it, DEAL WITH IT
also, using Sunoco Ultra 94 is pointless.... you're not going to get any better mileage with it. The mileage has to do with everyone's driving habits...... plain and simple.
Old Sep 3, 2003 | 11:51 PM
emailists's Avatar
I have no problem adding oil- I knew before buying thanks to this forum. I just want to be sure my particular engine is within spec of what oil usage/milage should be.
Regarding Sonoco Ultra - I did a an Ultra 94 VS. another premium gas with my Probe GT 94 on the same trip and got a few miles per gallon better with the Ultra 94. I have heard it said that when tested it was the only gas that actually had more energy than any other brand.
Old Sep 4, 2003 | 12:00 AM
kadunkadunk's Avatar
Everyone complains and says rotories use oil. Most GM V8's use like 2 qts in 3000 miles. At least my 8.1 liter does. Dealer says it's Normal. It even comes with a low oil light when you are 2 qts low.
Luiss7
54
Aug 20, 2019 08:56 AM
yurcivicsux
192
Sep 12, 2017 10:54 PM
JAYDOH
Sep 24, 2015 01:54 PM
Tsurugi
Sep 7, 2015 08:27 PM
